Ok... I think I lied.... but not on purpose... I actually think the next mod after tint was the installation of my Rosen CS- GM1210:
https://www.adcmobile.com/product/cs-gm1210-ca/
The reasoning for this is because I absolutely HATED the original GM Navigation unit that came in our '08 LTZ.... I don't know how much better the newer factory Navi is but I seriously doubt it could be any worse. The sound that came from the original head unit through the Bose system sounded flat and boring.... when I am jamming out to Johnny Cash I need to hear some bass... and the maps and Navi interface were awful and no Bluetooth in '08. There is probably more bad I could say about it but I will move on.
I went with the GM1210 after a lot of research. I liked it for many reasons. For one, it had Bluetooth, so that was an automatic upgrade. One of the main reasons I like it is because it looks stock... I know, crazy right?....
Remember earlier in my thread where I said "less is more" and "Chopper Clean".
I didn't want to come out and find my window busted and a big hole in my dash along with cut wiring and broken dash pieces, you know the routine. Plus I have had all the fancy doodads and gizmos through the years and I'm not trying to impress anyone any more... I've gotten to the age where as long as I'm happy with it, that's all that matters.... OH, and the wife.... HWHL remember...lol
Horrible pic, I know, and that's ok because everyone knows what a factory Navi looks like... which this isn't, but if it were off its hard to tell the difference.
Here is another pic just to show what the Nav screen looks like... Bear in mind, I live out in the sticks so there isn't much around to show up on the screen. Even so if you have ever messed with the factory Navi you should be able to appreciate the difference.
I also decided that since my truck had 2 cig lighter plugs in the dash, because in '08 the USB plug was not an option, I was going to change things up a bit.
I installed the factory USB port and matching cover on the passenger side and on the driver's side I kinda did my own thing.
I measured and researched and hunted and procured a 3 way toggle switch that just happened, by chance, to fit exactly in the original cig lighter cover and housing. I hooked the lower side up to a 5 pin relay that is mounted under the dash in the kick panel where the wiring block is located. The relay was required to maintain the factory functionality of the rear camera coming on when you put the truck in reverse (5th pin = NC) but the other pin ( 4th pin = NO) allows me to power up the rear cam while driving forward or anytime the truck isn't in reverse. This allowed me to NOT have to power the rear camera CONSTANTLY, which would cause premature failure, just to be able to view it while moving
The top portion of the switch is wired to the front camera I installed in the lower portion of the grill. It is nice when parking.
I did have to grind just a bit off the inside cover to clear the switch. I should have probably done a little better job of cleaning it up and smoothing it out BUT it stays closed 99% of the time. It's cool to because if you have either camera selected, when you close the cover it automatically turns it off.
