Double din install any tips
99blackburban
Kentucky
Metra makes a nice ddin conversion kit gives you a template for the trimming part# is 95-3003G
4myfreedom
4myfreedom
Washington, DC
Hey maybe you can help i also replaced my dash bulbs with LED when I reinstalled my cluster the lights don't work. dimmer works all engine lights work. Just the light that I replaced dont work any clues?
4myfreedom
4myfreedom
Washington, DC
Got a pic of the install?
Used dremel to sand down used metro dp 3003g used some jb weld to seal the deal
I have a build thread, but I have an 03. I think you have a similar setup. Do you have the replaceable plug in bulb, or do you have to replace the entire headlight if it blows out?
4myfreedom
4myfreedom
Washington, DC
Replace bulb
Any issues ? Over heating ?
None so far with mine. I have the flexible braid, not the ones with the cooling fans.
How long do they last ?
I think somewhere around 50,000 hrs maybe. I did have an early failure, which they did cover, but it came from China/Japan. Overall I'm happy with them.
johnsonwillie199
