Has anyone installed OEM carpet themselves?
not hard at all. The key to installing it and getting it to lay flat is heat. while you're taking out your seats lay it out in the sun. May also want to lay it out in a large space (garage, basement,....) a day or two in advance of doing the job. Then when you go to put it in you'll also need a heat gun to get the carpet to lay down snug to the floor and work out any wrinkles that may be present. You'll need a knife to cut the holes where the seat belts bolt to the floor and where the seats bolt to the floor.
I have done mine before it was pretty easy once everything is unbolted and removed, the payoff is always nice
K
KilluminatiDre
Ok thanks everyone. I was gonna get a brand new OEM takeoff from ebay for about $100 shipped. Shops around here want $200 for labor so I was thinking of trying it myself. My rear seats and center console are already removed. So what exactly hold the carpet in place?
PG01
Up here to the right
Nuthing, trim pieces by the doors.
Lightning 95
Fosscore
I would be worried about the shape after it got folded, rolled, and boxed up.
Shouldn’t be an issue. Mine can rolled and had the mass backing as well. Unpack it and let it sit in the sun until it looks good to go.
It will unfold and be ready for install. As well it will be easier to work with inside the truck on a warm day.
Drewphil
