Wiring Schematics 2015+
DenaliBQ
i am looking for the horn wire under the dash does anyone have a diagram on that or where i could find the horn grounding wire ?
Usdmskyline20
Does anyone know what impedance the Bose door speakers are ?
2011 Dodge Ram 1500 Big Horn
2017 Chevy Tahoe LT
cmatt
2017 Chevy Tahoe LT
I believe they are 2 ohm (2.3 technically).
cmatt
do you have the RH and LH side mirrors for a 2017 yukon xl Denali with power folding?
Are you wanting the connector view for the mirror harness?
vballrican
I know it's a little off-subject but do you have the schematics for the rear buttons that make the 2nd and 3rd row seats go down and up? I want to move these to the dash and replace them if possible. 2015 Tahoe LTZ. Thanks.
vballrican
Hello people, i see Right Front Tweeter Speaker in both X2 and X3! :( Also, does my 2015 Tahoe LTZ have tweeters at all? Do i need composite speakers or component? Thanks.
Here are the wiring schematics for the Stereo and Amp. If anyone wants any other wiring let me know and I will post em up.
Radio
Amp - it is located behind the jack bracket in the rear of the vehicle.
Jeeper350
15 to17 tahoe jumpseat wiring diagram adding the console to my 2000 pickup.. and wanting to use what I can from the console. Mine doesn't have rear ac controls. Thanks
Trevor brooks
Hi is there a post for the 03 tahoe engine bay wireing scematics im starting to wonder about switching some of the lights and horn wires out to a 18 ga. Wire and more substantual connections
Msalinas408
Radio
Hey man, any idea how I can disable the door chime?
Steve1985
Radio
under the amp section t3 audio amplifier x1..
i do not have a amp but i am wondering if that plug in the 3rd row that is at the area that the amp would be at is the plug for the sub ?and if so could i tap ito that plug sub pos and neg to run to my lc8i? when i removed the int panel there was 2 plugs on for the 12v cig lights and 1 just hanging. is that the plug that i can tap into to grab the sub pos and neg?
RST Dana
OH
2020 premier, I need a location near drivers a post for 12 volt acc
cmatt
Your best bet is the LH dash fuse block. It's behind the dash trim panel that's facing the door. There's a number of B+, ignition and accessory circuits there. For example, in the X1 connector you see when the trim panel is removed (larger connector with a cover over its wires), pins 29 & 30 are 15amp fused run/crank circuits. It's worth using a multi-meter to probe the "not occupied" pins noted below for 12v when the ignition is in accessory and then run modes to find what you need. The circuit number can be searched in the upfitter manual to ensure it can handle the amperage for your needs.
2015TahoePPV
NC
steering wheel wiring for one with buttons and without? I think the illumination circuit is in a different pin between the two
RIgeek
Rhode Island
Hello all. I've gone through this thread and the one bit of info I've not been able to figure out is this. I have a 2015 without factory amp but does have the 2.75" tweeters in the dash with 6x9 in the front doors. Is there any factory crossover (bass-blocker) anywhere in the factory tweeter wiring?
I've replaced the 6x9" in my doors, running new wire direct to my amp but would like to replace the 2.75" dash speakers and run them off the deck. Not sure if I will need to run my own wire to bypass any passive crossover that is inline from the factory.
My plan is to add in my own passive crossovers to the new 3" replacement speakers, I just don't want to run wire parallel if not needed or have the power loss of having passive crossovers in series.
Thank you all.
RIgeek
Rhode Island
Nevermind. I found that the dash speakers are parallel to the door speakers and have capacitors on the sides for their highpass filter.
GeroniMoe
South Shore, MA
I'm sure I missed it, but haven't come across it while digging around today:
Looking for constant and RAP 12v connections in the overhead console area to hard-wire a camera that has "parking mode".
2020 Tahoe LT
Thanks!
p1zaul
Radio
Are there harnesses for the amplifier connectors to swap out the amp with an after market, or at the least can the MOST serial data wires be converted to RCA connectors?
CKendrick
