Oil cooler line & trans cooler line replacement
domoarigato
Hey guys!
Popped the hood today and noticed a few lines seeping. I just want to double check with you PPV vets before I go ahead and order parts.
Correct me if I'm wrong... but the lines going into the radiator on the drivers side is for the oil cooler, and the lines going into the radiator going into the passenger side is for the trans cooler.
With that being said. Since this is a PPV I believe I need lines for the HD trans cooler right? I have pulled up the following part numbers:
Trans Cooler Line: ACDELCO 25999420
Oil Cooler: ACDELCO 20828695
Is there anything else I'm overlooking?
Thank you!
D
domoarigato
You are correct.
I replaced my oil lines a few weeks ago. My lines were seeping pretty bad.
The part numbers I listed look good? Either way, I already ordered them and will know shortly :)
I'm assuming all the oil has to be drained first correct?
CrashTestDummy
Pearland, Texas
I haven't done this, but suspect there's an anti-drainback check valve in the oil cooler circuit, so draining the oil, or removing the oil filter will get you nothing but two messes. I could be wrong, but I bet all you can do is pull the line from either end to start it draining. I think I'd start at the engine end, unless the FSM says differently.
UPDATE: FSM goes front to back. I'd have to get under the truck to see which direction I'd think would result in less of a mess, though. I suspect it's just something you'll have to expect to get oily doing.
992dr
Eastern N.C.
You're good to go :)
This is what I used = ACDelco GM Original Equipment 20828695 Engine Oil Cooler Hose Assembly
I did not drain my oil.
I had just changed my oil before changing the lines. Why, don't ask :) I just unhooked them and pulled them off. Just be prepared for some oil to drain, not really that bad. I did unhook the top to help them drain.
CobraKing
@domoarigato @992dr How hard was it for you guys to change these lines? Noticed some droplets on the driveway this morning towards the front of the vehicle and I think I may have to replace these lines as I had noted some seepage when I first picked up the truck.
992dr
Eastern N.C.
It wasn't bad at all. Being 2wd there's plenty of room and the lines are flexible enough to maneuver down and around the motor and over the cross member.
992dr
Eastern N.C.
It's that time of the month for a few of us evidently, my trans cooler lines are seeping enough to leave about a 2" wet spot overnight.
When they go, they all go together hah.
My trans lines haven't started yet. My coolant line/adapter coming from the water pump is leaking though. Some weird looking fitting and its all plastic.
D
domoarigato
It wasnt bad at all like @992dr stated. I did it while I did my oil change to minimize the amount of oil that leaked out.
My replacement lines from AC Delco did not come with the quick disconnect retainer c-clips so be careful when you remove yours because you will have to re-use them.
The only bad part (which wasnt that bad), was fishing the oil line out / in. It helps if you have another set of hands but I managed with myself.
It also helps to unbolt a few of the undertrays to give you some more room to work with.
I still need to do my trans lines. They seem to be a little more harder to access than the oil lines. Let us know how it goes.
CobraKing
@992dr @domoarigato @RichardCranium Thanks for the insight and replies. Did a bit of research on some other forums and some guys have said that adding some additional clamps might help. From your observations do you think it would?
992dr
Eastern N.C.
Yes, I removed both trays helps a bunch, it really opens things up.
Fishing the lines through was a little tricky but like Jake said, its not that bad. I also did this by myself, it wasn't too bad. Just be patient and it'll all fall into place.
Hmm, not quite sure what you mean by additional clamps? What would you need additional clamps for?
To hold the lines after they were installed?
CobraKing
Adding the clamp would stop the seeping. That's what some people were suggesting.
I'm going to put the truck on my ramps tomorrow and take a look and see if the above fix is viable. Shouldn't cost too much in the grand scheme of things too.
992dr
Eastern N.C.
Do you have any picture of the clamp and where it is affixed to?
I have not heard of this method to eliminate the seeping.
Thanks
992dr
Eastern N.C.
Jsal13
Hey guys!
View attachment 317581View attachment 317582
View attachment 317583 View attachment 317584
Thank you!
For the trans cooler line is it 1 or 2 lines ?
mikez71
There is another separate line from radiator to cooler.
Technically 3 lines, but two part numbers.
eegrobert
