upgraded sway bars
1999hoe
aka HOVERHOE
Massachoochoosetts
have any of you replaced your sway bars for an upgrade if so could ya point me in the direction you got it from for the tahoe 2 door? thanks
992door
Greenville, NC
would like to know also probably need to replace the one on the front
haks310
Got LEDs?
SoCal
Only ones I have seen are the Hellwig ones. Believe SummitRacing carries them.
992dr
Eastern N.C.
I didnt have a rear bar. I got the Hellwig from summit. Great kit, comes with everything you would need. Well worth it in my book.
smrr1
hmmm. i'll have to check if mine has one or not. i wouldn't mind a little less body roll. i'm used to trucks that have some but not as much as this 2 door.
foreverfalcon40
A vendor here sells them.. lets try another group buy. I want frotn and rear with with energy suspension brishings
sparg93
Expedition Tahoe
NJ
i have energy bushings on front/rear...the red ones look cool, but the blacks ones are impregnated with graphite and supposedly squeak less b/c of some self lubricating propoerty they supposedly have.
It's an easy install, just a lot of rusty bolts to undo which could take it from a 1hr job to many hours cursing as you bruise your nuckles like i did.
---------- Post added at 03:45 PM ---------- Previous post was at 03:43 PM ----------
oh...its pretty easy to over torque the bolts and there is no nut on the back...(again, learned the hard way) so the bolt(s) will fall out when you over torque.
Chevyrider619
Virginia Beach
I have my hoe raised up too w/o sway bars... Ever since i put the new diff.aluminum cover the one i had dont fit but,hey if the group buy's going,i'm in it..
smrr1
in for group buy! lets get it done. who sells them and can i get a link to the specific product? i'd like to check em out.
Hodmjstone
