No, I did NOT replace the socket yet. What I said was that I replaced the bulbs, and as I was replacing them, I noticed that the socket us so burnt up now that the bulb doesn't work, so I HAVE to replace the socket at this point. I've known this for a while though so it's not a huge surprise.
And as far as the bulbs, I've been using 3157's in my DRLs for the last 10 years. The base on the 3157 is the same as the 4114. The issue with the burnt DRL sockets seems to be a common occurrence, but I have also heard that it's caused by using 3157s instead of the 4114 bulbs. Who knows....
you can probably get that socket to work by just scraping the contacts with a small screw driver and then bending them In a pinch, mine were toast but I made them work again, the replacements are garbage compared to the originals but that's the way it goes, even when you replace them they will burn up again in short order.
Bombsquad85
Northern VA
So is it safe to say that a 3157 socket can be spliced in safely? And a 4114 bulb will fit? I got these fancy new LEDs and I just want them to work
Rivieraracing
Had the alternator die on my wife while taking the kids to school Thursday morning so ordered and installed the replacement on friday, truly the easiest alt install I have ever done. Nice having the denali back up and running!
Sent from my SM-N910V using Tapatalk
inmypassatlife
I've been on the search every day for a used oem Denali cover. Would love a duraflex but wouldn't love the shipping. I hate our 3 piece bumpers, rather have the smooth look of a 1 piece cover.
Just get a reman part. It's like $100
Merc1973
Maryland
Changing the oil tonight after work.... Im thinking about doing SEAFOAM through the Vacuum line for the first time in my 230k mi Yukon. Would you do it. Ive only owned it for a just over a year. Slightly rough idle.
Should I change plugs (not that old) and clean O2 sensors or is that nor necessary?
PG01
Up here to the right
I wouldn’t vacuum line it yet. I would hold off on changing oil put some seafoam in the oil for a week also dump some in the gas tank if you run it through the vacuum line it may loosen up too much carbon and then you’re going to block everything up. Don’t touch the O2 sensors unless you’re changing asking for trouble
Edit you could change the plugs after you seafoam oil and gas mbut seriously would not vacuum line it
95escahoe
Did an oil change on the Escalade last night, and got the headlight switch & foglight switch in can’t wait to get the rest switched over to blue LED’s, hit up @ScottyBoy for all your interior LED lighting needs
TheAutumnWind
Got 4600s installed in the front with resistors. No warnings yet...
Also installed my steering damper finally!
The escalade feels great!
******* found some torn boots on my uca ball joint and on my outer tie rod end though which pisses me off because they only have 10k miles on them and this escalade is stock ride height! ********. Both acdelco advantage parts. I learned my lesson... Moog problem solver or pro series Delco only.
Got the boots replaced today. Grabbed some of these for a few bucks. Fitment probably isnt 100% perfect but holds grease fine. Ill keep an eye on these. I inspect and grease with every oil change.
Energy Suspension 9.13101G O.E.M. Style Tie Rod End Boot, Black - Pack of 2 https://www.amazon.com/dp/B000CN7B5C/ref=cm_sw_r_cp_apa_ypWoAbQT2XEER
TheAutumnWind
The bulbs that came with the fogs are 899s which are 37w vs the factory 880s @ 27w. They are better... But id love to find leds that match my headlights which are d1r (the later escalades came with stock hids) osram "cbi" @5000kish.
Merc1973
Maryland
I just put in some in the oil during lunch today planning on changing it tonight. My only free night to do it.
I will wait unitl I do a full tune up to do the intake, thanks. Besides i need to chage
Thanks, I took your advice. I ended up just changing the oil last night. Forgot I Seafoamed the gas tank too. After a day of it running through. the idle is smooth as glass again.
I was going to drain and fill my rear axle fluid, but there is no drain plug like I have seen on youtube... WTF. I guess I now have to remove and replace my rusty-crusty diff cover, already have a replacement cover sitting in the garage. I cant find replacement bolts anywhere for the diff cover. I will check NAPA later.
Why not use the old bolts? Just clean them up.
Merc1973
Maryland
I guess I could put them under the wire wheel on my bench grinder. They look like hell. The original owner towed his mid sized sailboat that saw saltwater boat lunches yearly, so my undercarriage is UGLY. :(
PG01
You dont see a little plug with 3/8 square in it on the rear? Look again...a 3/8 ratchet with extension fits it
drowssap
Colorado
White Vinegar will dissolve rust on metal.. even better is applecider vinegar.
Yeah I most definitely have never heard of that either and I am pretty good with those types of home repair ideas. For instance.....never wire brush your battery terminals. Get scolding hot water out of your faucet and just slowly pour over terminals and white crusty buildup. It will all just melt away leaving you beautiful clean metal contacts.
Phlipnstik
