Anybody rebuilds gauge clusters?
Brad poiencot
im looking to see if anyone can refer me to someone that rebuilds gauge clusters. I have a 2006 Yukon and a couple lights are out and the oil pressure gauge is pegged wide open. Was looking to do a complete rebuild and possibly convert it to leds
RED TAHOE LS
Rossville, Georgia USA
Speedometer Service, Google them to find in your zip. Most every metropolitan city has one, since that is where Dealerships send their items including radios/speedometers/gauge panels/clocks etc. Good luck.
David g..........:)
HiHoeSilver
Away!
Chicago
Digital dash solutions
adventurenali92
Big Bear Lake, ca
I recently had my steering wheel buttons redone with led back light. The gauge pros is what they’re called called. Used their eBay store. They are in seiverville Tennessee. They were pretty fast. Cost me like 4 bucks to send my buttons to them via usps priority. They got my buttons on a Monday, fixed them and shipped them back out on the same Monday. Costed $45 for their service and it’s great. So far so good!
mals
Western Mass
More than likely the pegged oil gauge is a bad oil pressure sensor. It's a cheap part and can be swapped out with basic tools and a lot of patience. It's located on the back of the block right up against the firewall.
ScottyBoy
Shreveport, La
I don't do "complete" rebuilds, but I can replace the stepper motors and replace all the backlights with LEDs. 90% of the time, that's all that goes wrong with them. As far as the oil gauge pegged out, that one is tricky. Is it the stepper or the sensor? I've replaced steppers before and the oil gauge was still pegged out. Try cycling the ignition switch. Does the needle go back to zero? Or does it move at all? If the needle only points straight up, or is pegged all the way to to right, then it may be bad. If it actually moves the full gauge sweep, then it might be a bad sensor. Also, if you have access to a good scan tool, you should be able to view the oil pressure on the scan tool.
Brad poiencot
Brad poiencot
I will check the ignition cycle today when I get off of work. I changed out the sencor on my Tahoe so I know it’s not bad. I’ll change the senor too, but I wanna get the gauges rebuilt also. How much do you charge scottyboy? And do you do the leds?
Brad poiencot
Brad poiencot
Well I changed out the oil pressure sensor and that was the issue. Only think I notice is my Tahoe runs at about 50ish oil pressure and the Yukon runs at about 30-40. Is that normal?
drowssap
Colorado
I believe there was a write up somewhere about replacing the o-ring or cleaning the screen on the pick up tube in the pan
ScottyBoy
Shreveport, La
Mine runs around 30-40 at idle, but around 60ish when I am driving.
jarydM
Lost in the Woods
Tennessee
damn, I didn't know they were that close. I can get to them in about an hour.
still cheaper to ship them.
JayC33
New York
I used https://www.gmgaugerepair.com/ full rebuild and LED conversion. They say they will repair and repair and ship the same day as received in most cases. Had the cluster back in my hands in a few days.
