Reverse LED Light Bar
dbbd1
At some point during my meanderings, I can across this post (#28).
http://www.tahoeyukonforum.com/thre...with-philips-921led.78478/page-3#post-1069513
So, I wanted to show what I did. I actually used 27w LED pods, not necessarily a "light bar." I made a stand-off for each light from 3" square tube, painted them and used an existing body (?) bolt that went through the chassis. Angled slightly downward, they work great, not too much light cutoff from the body and barely visible. No beautiful body lines ruined. Power? I cheated. I used a 7-pin trailer plug and plugged it into the trailer outlet. No wires to run, no relays to add. If I'm towing, I disconnect it and hang it right there (I bought a rubber cap for the plug too). If I'm towing, then I probably won't be needing those backup lights anyways.
S33k3r
Dallas, Texas
It does look great, but do you have any clearance issues? They look like they hang down a good bit.
dbbd1
dbbd1
No clearance issues. It's the angle of the pic (I wanted to show the bracket). They are only about an inch lower than the spare (and I'm only 2wd).
gat0r
DFW
nifty
how bright are they ?
& how well does it show in screen?
dbbd1
dbbd1
Okay...
They are plenty bright and help a lot.
I guess more pics are on the way (rearview screenshot and dude shot showing clearance). Tomorrow.
Ct Pirate
Senior Member
I've got some spare 7" LED bars sitting in the closet from the Jeep Wrangler build maybe I'll follow suit.
dbbd1
dbbd1
In the first pic, taken fairly level to the ground, you can just see the added light hiding behind the exhaust tip. The front end of the spare is actually lower than the light.
The second pic is just my upgraded LED bulbs in the stock housings.
The third is with the led flood light pods too.
dbbd1
dbbd1
I never noticed this before but, for some reason, the added lights remove some of the washout that you can see (in the second pic) that is close to the back end. Probably helps provide more ambient light so the camera aperture adjusts for it.
S33k3r
Dallas, Texas
Thanks for the additional pictures. This looks like a really good solution to the problem my wife and I have with her Tahoe and my Suburban.
sumo
dn ʇǝƃ ʇuɐɔ & llǝɟ ı
rhode island
Nice. Many years ago, I had hids for reverse lights. Now that was bright
Youngerjc
View attachment 188453 View attachment 188454 View attachment 188454
how did you wire them to the trailer plug?
dbbd1
dbbd1
I bought another 7-blade plug and used that. Yeah, cheating, I know. When I tow, the trailer is plugged in but I don't need the backup lights then, anyways. The backup lights plug and cable is short, I just drape it over the top of the receiver when not in use.
RST Dana
OH
Why does your receiver cover look like it has lights? That is something I might consider.
dbbd1
dbbd1
Because it does have lights.
3 LEDs that pop into rubber grommets. I cheated even. I wired them into a 7-way trailer plug. If the cover is off, because I'm towing, then the plug and lights are removed too, no biggie, nothing in the way.
Korbin_A
