2016 Denali-leveled on Ridge Grapplers
JennaBear
Resident Ninja
San Diego, CA
Got a few PMs on my set up, figured I would post it in this SubForum as well.
Really happy with how everything came together, no rubbing with 1.5" SuspensionMaxx leveling kit.
I was able to squeeze 33x12.5x22 Nitto Ridge Grapplers on there.
PG01
Up here to the right
Looks good jenna
JennaBear
JennaBear
Resident Ninja
San Diego, CA
Love the look! I wish BFGs were available in 22s or Toyo/Nittos were severe snow capable.
I ran NTGs in the snow for quite a few years no problem. We will be moving to a snow laden area within the year, so I can give more input once there.
Sent from my SM-G950U1 using Tapatalk
Redbeard1
Have you noticed your yukon riding any differently since installing the strut spacer? Magnaride acting any different?
Ct Pirate
Senior Member
WOW she looks great! Just something else to drain my year end cash. But looks sooo worth it.
JTRATX
I just bought that same kit. Did you adjust your headlights after level?
gonatee
Awesome! Looks great thanks for sharing!!
The lift probably helped the angle of the headlights since there pointed at the ground outta the factory and have to be adjusted by factory according to the manual
gonatee
I see a L/R adjuster on the headlight but not up down. Manual says it's factory set and needs to be done at dealer? :)
ethansun
Looks great! I will probably go with your route. Is wheel alignment required after level-kit installation plus bigger tires?
Durobans
