2001 Tahoe headliner foam board
mbp1979
North Little Rock
Do anyone know if there's a difference in the headliner foam board between a lift gate model and the barn door model? I need a new model that hasn' been cut from the overhead console that house a tv that no longer works.
M
mbp1979
North Little Rock
If the trim piece in back at top is same on both then yes, same thing
Well I have the barn doors and the one I'm looking at getting is a lift gate model but it's a 2 hour drive one way so I'm trying to find out ahead of time if anyone knows forsure.
PG01
Up here to the right
Really think the only diff is on the outside of truck, meaning there is a catch for the door up top outside of truck vs lift struts on the sides of truck, interior trim piece is same. Im tryingvto google images of tahie interiors to see.
M
mbp1979
North Little Rock
I've tried doing the same and can' tell I was just trying to see if any members had first hand knowledge of this is I know guys have swapped them out before. But maybe someone has tried between the two different styles.
YukonXL04
The Riverboat
Arlington, TX
Is the Tahoe a single piece headliner? I know on my XL and suburban it's 2 piece. But I believe everything on the inside Is the same between barn doors and lift gate as far as trim panels go.
Yes it is. The Suburban and XL are obviously longer, so it's in 2 pieces.
M
mbp1979
North Little Rock
So has anyone run into this before. I'm trying to find out before tomorrow I'm supposed to make the drive to go get it and don' want to waste everyone's time if it is going to work
RED TAHOE LS
Rossville, Georgia USA
To be correct, call the dealer for part # of each exact vehicle option, you will know for sure. Mine has barn doors and the very top does not look as fat as a lift gate model. JMHO , good luck.
David g............:)
I'
I'm 95% sure they're the same.
CrackerJack135
