drowssap
Colorado
Thanks looking to LOC for truck. Best place to tap in is where?
Depends on the system that you are getting together. If all you want is bass....tap into one of the main rear speakers. If you are going with high end sound....the fronts and you need to use a DSP and not a loc
02_Tahoe
Maryland
Gave it a bath, and pulled the trigger on all the parts to complete the NNBS front brake upgrade (rotors, pads, calipers), refresh the the stock NBS rear brakes (rotors, pads, and parking shoes), and replace all the flex lines with stainless.
Is it possible to put nnbs brakes on the rear also?
02_Tahoe
Maryland
Anyone interested in buying the stock running boards? Also have an amp for sale that I thought was blown but happened to just have a bad ground
dantheman
Houston
slammed a cam and valve springs into the 5.3 out of the suburntban
working on swapping it into this
heres a test fit i did with a bare block i have.
ASG-MikeS
