Brakes are farting
CamReynolds
My brakes feel fine until you have to brake with any force. The truck shimmers and the brake makes a noise that sounds like a fart/dull squeak. I've never redone the rotors so I'm hoping it's a rotor problem not a master cylinder. What do y'all think it is?
afpj
Kinda sounds like the abs kicking in.
Danny3737
Does it sound like this?
afpj
What's your brake setup? Stock? Drilled/slotted rotors?
M1Gunner
Gainesville, Fl
One thing to look at, not saying this will solve your issue, but get a scan tool and check your wheel speed data. If there’s one that’s cutting out at low speed, which gm wheel speed sensors are known to do, you’ll get an unwanted abs activation resulting in the symptoms you are having. Again, not sayin this is your problem but it’s just something to look into.
CamReynolds
CamReynolds
The abs seems to only come on at 10-0 mph so I'm hoping it's just a bad sensor
CamReynolds
CamReynolds
Sounds about right. Parking lot coasting...
Hope so brother, keep us posted!
so my wheel bearing was bad, which made the wheel shake, which made abs come on. all fixed now. hopefully this spell of maintence work is over (axle seal, rotors/pads, bearing, abs).
GMT800 2005 Tahoe Z71
Navy Supporting Member
Your ABS can make a groan noise or what you may think sounds like a fart. I would not think it is a fart noise unless you get that damn smell right along with it. At that point I would blame "organic" brake pad compound as the culprit. But that of course IMO.
CamReynolds
CamReynolds
i thought it sounded like a fart, but its just the abs compressor haha
Skiroy56
