Whipple is installed
Fifty
I think I found it. It was cutting the fender wall of the intake box right?
iwaslowr
iwaslowr
ɹǝqɯǝɯ ɹoıuǝs
Austin, Tx.
With my K&N intake and the IAT’s are just a few over ambient...
NGAneer
NWGA
Yes. There is a plastic brace that runs diagonally across the "mouth" of the intake box. I cut that out and the corresponding metal on the inner fender.
Fifty
How accurate is the dashlogic with boost?
iwaslowr
iwaslowr
ɹǝqɯǝɯ ɹoıuǝs
Austin, Tx.
so far, it has been very accurate for me. i have 3 bar sensor installed.
gat0r is correct. The OEM MAP doesn’t read higher than 2psi. I too have GM’s 3 bar sensor but it can’t be installed until the tuning is done. The boost reading without an additional gauge/mount/etc. is the main reason for my buying this DashLogic/AutoMeter DL1061U.
Fifty
So the dashlogic will read correct with the 3bar and the whipple canned tune?
Does the whipple kit come with the 3 bar map sensor?
iwaslowr
iwaslowr
ɹǝqɯǝɯ ɹoıuǝs
Austin, Tx.
Whipple’s tune requires the factory installed MAP be re-used, unfortunately. Upgrading to GM’s 3 bar MAP requires a re-tune.
CooperS7777
Does the dash logic have to stay plugged into the OBD-2 port for functionality, or are the changes made and the dongle removed?
gat0r
DFW
^ DL has to stay in to work. as it reads OBD2 data
JJB809
Hello amigo, could you share with us the parts you bought for the dashlogic/autometer please.
Thinking doing a hidden OBD Y for this.
Thank you
JJB809
dbbd1
Thank you
JJB809
Unless something has changed in the past couple of years, you can only use one thing at a time in the OBD port. You can have two things plugged in, using a Y but, the way it is addressed, only one will work. The exception to this is if one of those items is only a power port (not using the vehicle network).
Unless, of course, you are doing this just for aesthetics...
gat0r
DFW
^ as mentioned above, only 1 OBD2 item works @ a time.
i just plug mine in when i want to see data.
there are some that bought a 90 degree adapter to tuck their DL under the dash
(cable is avail on amazon)
get ready mine runs low 12s on the BIGGGG PULLEY lol I like how the whipple fills up engine bay more
https://www.instagram.com/p/BUOOODFFL10/
I have a 16 denali, what yo do the Whipple set like yours. (Is the larger pulley and Z06 fuel pump required or just recommend) I’m also looking to do front and rear wilwood TX6R big brake kits. Any chance you send me some pricing and your recommendations. I currently have an AFE intake and corsa sport exhaust. Thanks!
Want to *^
Conedaddy
