so it begins again....2017 LT build
GusSanchez300
GusSanchez300
Miami FL
Out with the old
GusSanchez300
GusSanchez300
Miami FL
After 2.5 hours fighting, I succeed made 2 tiny mistakes but nothing serious thank God!!:chewie:
Gas tank got mil a bit by the hacksaw and with the grinder when removing the weld it went into the frame about an eighth of an inch by about half inch, so I have a light weight frame now :anitoof:
Fosscore
That free travel mod will make a world of difference. I rode around for a long time before I cut it off and now it rides much better. Would like that upgraded sway bar though. Nice work man.
GusSanchez300
GusSanchez300
Miami FL
Thanks, why does it make that much of a difference, doesn't just allow the truck to have Moore travel while going over a bump? What does it do to the regular driving? There maybe something I'm missing lol
Fosscore
Nothing really noticeable to regular driving. Gives the truck more travel over the bumps when it is lowered versus with the OEM bump stop still on the frame. I can still bottom mine out say over a rail road track if I wanted to (I did right after I cut it off just to see how far it would travel, but not since.)
Your everyday driving will just a bit tighter. Lower center of gravity, tighter suspension, better components, less sway. For the almost 3 ton beast, this is a winning combination.
GusSanchez300
GusSanchez300
Miami FL
Sounds good to me, thanks for the input
Fosscore
That looks good man. You might need to cut that bump stop down a little bit.
See mine here. I had to cut 2 of the layers off on mine. And you can see where it has made contact on the frame.
GusSanchez300
GusSanchez300
Miami FL
Still can travel about
They are very small yours seems like it was twice the size of this one's but ill keep an eye on it, I have bags too so it shouldn't be bottoming out unless is something massive like trying to catch air like the dukes of hazards lol
Here is one more on clearance
Fosscore
Man that looks badass!
Just FYI. Here is what my bump stop looked like before I cut off the top 1/4” and another really lower profile option. They have so many if you find that one being a pain/too close to the frame.
Either way nice work on the drop.
GusSanchez300
GusSanchez300
Miami FL
View attachment 185659 View attachment 185660
Thanks it was a mission but can't believe is almost done lol.
I have to say that the truck looks pretty good even on 20"
scottd
