Crazycrew's 2013 Denali CCSB Build Thread
kwOH
Banned
It's 3.5/6 now. CV's are slightly negative. Zero binding
Sent from my SAMSUNG-SM-G935A using Tapatalk
Whats your fender to ground measurements? Are you level right now?
Sent from iPhone 7 plus using Tapatalk Pro
C
crazycrew
Vacherie, LA
Ehhhhhh, they're wonky. I've been taking top of center cap to fender. Don't really have any ground to fender
kwOH
Banned
Front to back tho, do you feel like its level? Looks pretty level to me, just wanted to get your opinion on wether or not you think it needs to go 4 in the front?
C
crazycrew
Vacherie, LA
It's just a tad lower in the rear. I'm definitely going 4 in the front, but not until I notch it and swap back to the stock hangars
The Chevy Lean is why I'm dropping the front with relocators (in addition to the spindles). I'll probably leave one of the spacers on the left side.
C
crazycrew
Vacherie, LA
Claybar, polish, and sealant today on this Ole *****
C
crazycrew
Vacherie, LA
Ok, so nothing much new here, but I did order a bunch of parts and fixed the Chevy lean.
Ordered weld in underbed notch, mcgaughys helper bags, belltech 2210FF steet shocks, and coil relocators for the front (removing bt struts)
So, since I first lowered it, I've had the flip kit, hangars and stock shackles, and Monroe air shocks, about 6" drop. I've been wanting to swap to the factory hangars. So I disconnected the shocks and measured.
Holy shit, almost 13/16 higher on pass side. I swapped the pass side only to the factory hangar. Perfectly even measurement after.
dizhai
