LS 6.0 swap happening!
bigfootchiro
Largo, FL
So I've decided to pull the trigger and do a 6.0 swap. I've done research, but still have questions. First off, I'm going to keep the 4L60E that I have til it blows, then either build it further or swap a 4L80E (or a 5 spd upgrade). I'm not 100% sure what my trans is built with; however, the previous owner said "it's built". We all know how that goes...
I have access to a 2005 6.0 from a Yukon, with all accessories including harness and PCM. Will the PCM need to be retuned, since it was made for a 4L65E, or are they practically the same, besides beefier internals? Or should I just swap in an 80E?
The engine is going to get torn down, dipped at the machine shop to have it cleaned, inspected and all seals replaced. The heads will be getting some work done to them, along with a new cam and springs. Should I go with a custom cam, or does anyone have any suggestions? I have stock stall converter, 3.73 gears and 35" tires. Looking for a decent lope at idle and good fuel mileage. By good, I mean currently around 12-14. I would like to stay in this range, if possible. I've looked into TSP220, 225/236 Hot Cam, BTR Stage 4 224/230, and many more. I'm thinking the larger cams may bring the powerband too far up in the RPM range for my gearing/tire size/stall; however, correct me if I'm wrong. I MOSTLY daily drive, with occasional towing.
Also, any suggestions on head work for the stock heads besides a spring upgrade? Porting, decking, etc.
All work will be happening in my friend's shop who builds race cars, so access to tools will not be a problem. They will be doing most of the work, but I will be involved after hours when I'm done at the office and on the weekends.
It's going to be a fun project, and cannot wait for it to be done! Any other help and input for this swap would be appreciating, thank you!
bigfootchiro
bigfootchiro
Largo, FL
Picked up this baby today!!! 2005 6.0 from a Yukon Denali. 120K miles
Nice! I did my 6.0 swap using a 6.0 from an 05 Silverado. Great motor. You can use either pcm. It'll need to be tuned either way for your upgrades. If your truck originally was a 5.3 , the 6.0 can run on the 5.3 tune until you get it flashed. Guys have done that with no issues, just don't beat on it. I forget what specs my cam is, but it has a nice lope at idle, and combined with my 3,000 stall, has lots of power for me. But I told the mechanic I didn't need it to go from light to light, just enough to stretch its legs on the highway. So your specs may vary. My stock transfer lasted about 3 months! Once you blow yours, you can build your trans to handle what you have. Make sure you have all the supporting mods along with your cam, pushrods etc. Sorry I couldn't be more help. I'm sure other guys will chime in with better info. You can also check out my build page. There might be more info there for you. Please keep us updated. This is an awesome upgrade, and you're gonna be glad that you did it.
bigfootchiro
bigfootchiro
Largo, FL
Thanks @Tonyrodz ! My Tahoe is originally the 5.7 Vortec, so there will be more to it than if it were the 5.3. What trans are you using, and how does that high of a stall act on the highway? I'm definitely excited to get this project moving. I'm sitting down with my friend today to go over a game plan, then the work should start this week!
I had my 4l60e rebuilt with a little bit better internals, bands, also put a shift kit and vette servo. There's other stuff in there, but I forget now. So far, so good. The convertor feels pretty good , no issues there. Sounds like you have a nice little project on your hands. Def should do an under construction page. I know alot of guys will be interested in your progress. There's a member @Snowbound who was doing a similar vortec to ls swap who is very knowledgeable. Good luck with the swap.
bigfootchiro
bigfootchiro
Largo, FL
How's it holding up now? Supposedly mine has upgraded internals, but I don't know what, so I'm sure it's a matter of time. How do I do an under construction page? Ills definitely do a build thread there!
Mine is holding up great so far, but it's only been a few months. Just go to the under construction page and start your thread. It's just like a normal thread.
Subbed. I'll be following along. Another possibility for cam is where I went, Vinci High Performance. I went with their " Trucker " cam and dual valve springs. Roger Vinci himself will personally take interest in your project and offer help. Highly recommended.
bigfootchiro
bigfootchiro
Largo, FL
Thanks @Red Rocket , I'll be giving them a call! Make sure you follow along to my build thread, because I probably won't update this one here. How do you like the dual valve springs?
How much power are you running with the Trucker cam? I was looking at a couple on there, like that one and the Ultra Torque
I'm not sure, the only AWD dyno around here is 2 months wait. I have blown the trans and had one built to handle 800 HP. Just got it installed and broke a u-joint strap which did some damage due to the front driveshaft flopping around.
bigfootchiro
bigfootchiro
Largo, FL
Oh damn, it's always one thing after another when you start dropping in more power haha. I had a 99 Cummins with 638HP to the wheels. Ended up shooting a carrier bolt out the rear diff cover that left a huge hole! Didn't even know til some guy pulled alongside me on the highway and said I was leaking rear diff fluid. When I pulled that thing off, chewed up bolts were falling out left and right. The only thing still allowing me to drive was ONE loose carrier bolt hahaha.
Back on track here... do you think the dual valve springs are worth the upgrade, or are your typical 110-130 lbs springs adequate?
bigfootchiro
bigfootchiro
Largo, FL
I was looking at your build thread and saw WA plates! Are you in Oregon or WA? I was born and raised in Port Townsend/Port Ludlow, went to Cali for 4 years for graduate school, and have been in FL for just over 2 years now. I'll be back in WA for 2 weeks in December!
It depends on your cam. Your cam grinder should let you know. The Vinci Trucker cam requires them as well as hardened pushrods. Some of their other cams say " suggested". You should talk to your cam supplier and let them know what your goals are and they will come up with a complete package. If they can't then I wouldn't buy from them.
I bought the truck across the Columbia River in Vancouver but I live in Portland.
CrackerJack135
