Electrical
BegottenOne
I have replaced the starter, alternator, battery, belt, and ignition switch on my 04 yukon. It still hesitates to start what else can it be. All cables and grounds are tight. The starter will engage but won't turn the engine over.
Sent from my SM-G930T using Tapatalk
Poor ground connection from the battery to the frame and/or engine to frame? Damaged (corroded) cable from the positive battery post to the starter solenoid?
I know you said they are tight. But did you actually remove them and inspect for corrosion between the contacting surfaces and inside the jacket behind the crimped connectors?
How's your fuel pressure? Could also be a bad fuel pump. Try banging on the gas tank as someone turns the key.
B
BegottenOne
Fuel pressure is good. All cables are tight and connections are clean no rust or dirt on them
Wait- by "won't turn the engine over", you mean the solenoid on the starter engages but the starter won't spin the motor or the motor spins as it should when starting but doesn't fire up?
B
BegottenOne
It acts like the battery is dead but if I leave the key in the "on" position for 15 to 20 secs it drags like a low battery but engine turns over
Chubbs
a tight connection won't matter if corrosion has built up in The wires beneath the clamps. You have to remove each clamp and scrub everywhere with a wire brush before securing well with the bolt, which should also be cleaned well.
We aren't talking about the obvious attachment posts, but the wire underneath the clamps, that you can't see without disassembling.
I actually had some $hit identical to this short of the positive lead terminal that connects to the battery. AFTER I loosened the post clamp from the wire/lead, I found this corrosion underneath that could not be seen otherwise. Scrubbed it all out, secured it back to the clamp, reconnect to Pos terminal, good as new. I think you are overlooking something.
Look here
Remove these
B
BegottenOne
Look here
Remove these
I replaced both positive and negative terminals ends on battery cables when I replaced the battery. New nuts and washers and connectors on starter well. It's has to be something so simple that I'm over looking it but I'm dumbfounded on what it could be.
Chubbs
I hate that you are getting so much aggravation from this. and you don't have a CEL or any fault codes, correct? its common to experience CEL fault codes and/or error messages (DIC) for the transmission and ABS as those extensions flip out when hit with anything lower than your normal or spec voltage output.
Without knowing the history and jumping to conclusions, I would next be replacing the main leads & upgrading the gauge; its a mod called "the big 3," I believe, if for anything but an upgrade & possibly eliminate the culprit in process.
I would also be stopping into Oreilly Auto and getting whatever tested that I can. Maybe 1 of the new parts is compromised.
Chubbs
And before attaching the new clamps onto the cables you didn't do any prep work? That's where my issue was but I had to actually spread the wires out and scrub all of the corrosion out; it was embedded within the individual strands, I didn't see much outward sign of corrosion or contamination such as your typical green&ashy on the batt post & cable clamp as I clean that reg. I had to disassemble everything then untwist & spread the individual strands to find the root cause.
B
BegottenOne
Only fault code that displays is the replace liftgate fuse but that is sporadic. But that's been happening for awhile and never effected it. When the weather clears up I'm going to check all cables for cracks. All ground and power cables are tight and clean.
corvette744
2004 Z-71
Northern illinois
Get a starter draw test and batt load test done at you local shop,and check for a drain also-prob one of those.
MidwestMike
Southwest Michigan
You can put a meter on the battery when you try to start it and see what it does to get a little more information.
Make sure you are starting out with full voltage, which means the charging system is working and there is not a drain occurring. (The battery can read full voltage but still not be good..)
Now look at the results as you turn the key to start it.
If the battery is not dropping down, there is not much of a load on it and you need to look at connections.
If it drops down bad, it is a battery or bum starter drawing too much. (rare, plan it being a battery)
You could then swap a battery or have a load test done to confirm.
rockola1971
Indiana (formerly IL)
Battery should not drop below 10.5vdc while engine is cranking. If it does then the battery is on its way out. Turning key on (Not engine crank position) will show any shorted loads that are ignition only circuit.
retiredsparky
A faulty harmonic balancer can drag/lock up the crank against the block if the rubber disintegrates. Removing the belt may release the balancer enough to make it turn free.Very similar symptoms to electrical causes.
Larry
retiredsparky
Larry
bottomline2000
Dallas, TX
Check and see if you are losing coolant. U could pull the spark plugs and see if coolant shoots out when you turn the motor over. The motor could be hydrolocking. Pull the fuel pump fuse when u try this.
HeavyHoe03
