96 Tahoe dies while driving and won't start
Nightflyer
Bamberg, Germany
Hey Guys,
I'm Matthias from Bamberg, Germany. I've an 96 Tahoe (350 Vortec TBI) and a real big problem:
My car died three weeks ago while i'm driving (it was like, someone cut off the ignition) and won't start again. Nobdy in Bavaria and Germany knows why.....:(
- the battery is in a very good condition
- the car cranks very well but won't start
- the chevy has very good sparks
- the fuel pump is running and new
- fuel pressure at schrader-valve (is that the name?) is about 61psi and 63 while cranking
- changed the distributor cap, rotor, plugs and wires
- changed the ICM
- changed the CKP-sensor
- it misfires whit starting fluid (one time)
- the plugs are sometimes wet and you cann (sometimes) smell gas
- the timing chain is okay (tested with turning the crankshaft and look at the distributor..the rotor moves
sometimes it seems like, that the chevy would like to start. it sounds like, that there is no pulse to the injectors.
btw: there are no codes stored in the PCM and all cables ok.
Please: could someone help me? what can i test and look for?
Best regards from Bavaria/Germany
Matthias
p.s.: soorry fpr my bad english..;)
bigfootchiro
Largo, FL
Hi Matthias! Welcome to the forum! One of my good friends growing up was a transfer student from Germany named Matthias.
Keep in mind, I'm no expert when it comes to this, but I'll start by shedding some light for you, then hopefully more knowledgeable people will chime in.
How was the truck driving before all of this happened? Was it stumbling, misfiring, or lugging at all?
When you turn the key to the ON position, does the SECURITY light stay on, or does it go off?
Have you ever changed the original spider injection unit under the upper intake plenum? You can do a fuel leak-down test very easily with your fuel pressure gauge. Hook the gauge up to the schrader valve, turn the key to the ON position (do not start), and check your pressure. You said it was 61 PSI before. Turn the key OFF and see if the pressure drops. If it drops significantly over 5 minutes your fuel pressure regulator is probably bad.
I know you said you have good spark, but have you checked your ignition coil? Usually when people say something like, "someone cut the ignition," it's usually electrical related. Another piece could be the ignition switch itself has gone bad.
Nightflyer
Nightflyer
Bamberg, Germany
Hi Nathan,
Thank you for your reply..;)
Before this happend, the chevy runs very well...okay, sometimes rough idle (when it was very warm) and a little bit stumbling. but when i remember, the car ws often hard to start when the engine was hot....:(
I don't have any security light and it's the original spider injector inside (200tm).
Okay.....i've done the fuel pressure test. It's holding the pressure for about 5 minutes...goes a little bit down do 60 or 59psi.
I've changed the ignition coil...it's a new one.
best regards
Matthias
bigfootchiro
Largo, FL
Doesn't sound like the spider is bad. When was the last time the fuel filter was changed? With that much pressure, I would not think it would be clogged, but if it has been a long time since it was changed, might as well change that for maintenance.
What brand of ignition coil, cap, and rotor did you use, and how long ago did you change it?
There's the potential of a bad ground wire, as well. I'm mind vomiting every possibility that I can think of that would cause a no-start condition. Hopefully someone else will chime in, as well.
Nightflyer
Nightflyer
Bamberg, Germany
Okay,
I've doublechecked the spark plugs after some cranking the engine.....6 of them are dry...no fuel....:(
The fuel filter is new...changed it last month....;)
Ignition coil, cap and rotor are from delco.
Well, i can improve a ground wire an test it..
Nightflyer
Nightflyer
Bamberg, Germany
Okay....
All ground wires are in good condition.
I think it's better to install a new spider assembly....
What's the difference between cpfi and mpfi? is it easy to convert it?
I've seen, there are different diameter available...5mm and 6,5mm. My 8digit at the vin-code is an "R"...so i think i've 5mm injectors diameter, right..???
Best regards from Gerrmany
Matthias
bigfootchiro
Largo, FL
The spider may or may not be the cause, but if you're wanting to do it anyway, go with MPFI. The difference is central port vs. multiport fuel injection. The MPFI is with the upgraded injector unit that is controlled at each injector. I did the upgrade and the truck runs much smoother now. IDK what your prices are in Germany, but the cheapest I found was on Amazon. Even found some on eBay that were cheaper.
Nightflyer
Nightflyer
Bamberg, Germany
Hi Nathan,
I do not know what else it could be..:(
I've spark, Battery is in good condition, the car cranks, the fuel pressure is ok...everything i fine....but no fuel at the spark plugs and no trouble codes. The fuel reaches the schrader valve with the right pressure...:(
In germany is the spider-injector very expensive. The car is rare here...it's about 500-600€. Rockauto or ebay (with new FPR) ~240€ and one week....:))
I just need to know wich diameter in need....??
bigfootchiro
Largo, FL
The part number you are looking for is ACDelco 19210687. I've never seen a diameter size for the injectors, but that is the part number you would need. Can you post a link to the site where it asks for the diameter?
east302
Mississippi
Just to confirm, you said that you have spark at all eight cylinders, right?
Your fuel pressure is within spec (60-66 psi) and since it doesn't drop within a few minutes, your regulator and injectors should be good.
Have you done a compression test?
Do you have a scanner that can read the output from the engine coolant temperature sensor and throttle position sensor? Try holding the gas to the floor when cranking, see if it starts. That would probably indicate a bad ECT sensor.
You can test the ignition feed circuit to each injector and see if you're getting power to the main harness. Disconnect the harness at the intake and with the ignition on, see if you get voltage at each ignition feed circuit. It would be the pink wires, circuit 439:
If you have no voltage, look for a wiring issue between the fuse block and the harness.
Edit: could be a stuck open EGR valve, but I'm not sure how to test it.
Nightflyer
Nightflyer
Bamberg, Germany
I've spark on everthy cylinder, fuel presssure, etc..is okay.
My OBD-Software can read the ECT and TPS data...everything is fine.
I've never done a compression test...i think it's not necessary. The car runs fine and dies wirhout any signs of no compression or something else. The timing chain is okay.
Tomorrow i'll check the harness of the injectors.
The car is not starting while holding gas on the floor...i've tested it..:(
What is, when i have no power to the injectors?
east302
Mississippi
If you have no voltage to the injector(s) then look for a damaged wire between the harness and fuse block.
I would suggest looking at a stuck open EGR valve, but those should, in theory, throw a code when the pintle isn't cooperating. I know you can test it with a scanner, commanding the pintle position to certain points, but I believe that requires a running engine.
GM does have a procedure for testing individual injector solenoid operation and poppet pressure drop/flow, but the test equipment would probably cost you more than a new spider assembly.
What voltage are you getting for the closed TP sensor? It should be below 1.25V.
What temperature is the ECT reporting...close to ambient and not some oddball number?
The wet plugs does sound like leaking injectors, though.
Nightflyer
Nightflyer
Bamberg, Germany
So,
It's all tested:
- there is 12V on each injector
- 0.78V at the TPS
- the EGR looks pretty good (seems to be new)
- teh ECT reports the correct temperature
Not all plugs are wet...only two of them. The other six are dry....
bigfootchiro
Largo, FL
Here is the link....
http://www.rockauto.com/de/catalog/...5.7l+v8,1061356,fuel+&+air,fuel+injector,6224
In the ite description is 5mm and 6.5mm listed
The 6.5mm are the new MPFI design and the 5mm is the old CPFI, which you do not want. Click on the pictures and you will see that the 6.5mm is controlled at the injector. BTW, do not buy them individually. If you do buy it, buy the entire assembly.
And btw, @east302 is the man when it comes to this stuff! Glad he chimed in. He helped me a few times already through some issues with my truck. Thanks @east302 for helping people out on these forums!
east302
Mississippi
So,
It's all tested:
- 0.78V at the TPS
Does your scanner have history data for cylinder misfires?
Well, you've got fuel (or too much, which cylinders were flooded?), spark and air.
The next step, since you have power to the injector harness, would be to see if the computer is grounding each injector during cranking. A noid light would normally be used to see if it flashes during cranking, but you may have to rig something up to fit the spacing between the voltage supply and VCM circuit terminals in the main harness.
Or, you could put a test light to battery positive and probe the ground (or test light across the two terminals) to each injector during cranking and see if the light flashes.
I haven't done it, but I've read where you can check to see if each injector is spraying by disconnecting the coil and coil module, removing the upper intake, reconnecting the injector harness and then pulling each injector one by one to see if it sprays while cranking. Careful, it's fuel so use a towel or something. Also, those stupid plastic squeeze clips on the injectors can break.
It sounds like intermittently sticking poppets flooding out some of the cylinders. There is a GM procedure for cleaning them, but it requires the truck to be running.
If I was going to throw a part at it, it would be a new MPFI assembly. I did this on my 98 truck, and it was a noticeable improvement over my 98 Tahoe.
Nightflyer
Nightflyer
Bamberg, Germany
Hi east302,
Cylinder 1 and 4 are wet..the other are dry.
The history shows nothing about misfiring....everything else, but not this.
But i remember one thing: I've changed the spark plugs 3 or 4 months ago...and it looks like they are running with poor gas (not rich enough...sorry, my english is not so good..:(...) and sometimes when i start the tahoe it seems like, that not enough gas is coming to all cylinders. The chevy starts very slow. I hope you could understand what i mean....
Nathan & east302: thank you for your help. When it works and my chevy is fixed and runs very well, i'll send you some beer from Bamberg/Bavaria....;)
THANK YOU SO MUCH.....!!!!
Matthias
east302
Mississippi
Well, hope you get it figured out. Let us know if the new injectors solve the problem.
Your English, by the way, is arguably better than many Americans.:)
bigfootchiro
Largo, FL
Bahaha, right?! If only some Americans would try as hard as you @Nightflyer to speak proper English! I hear the beer is very good over there in Germany. I need to have a vacation over there!
east302
Mississippi
Yeah, I wouldn't mind seeing Germany one day. I had some German beer at DisneyWorld that was really good...I think it had (of all things) grapefruit in it.
Germans would probably think it wasn't a "real" beer though, lol.
dizhai
