Fabtech 4" kit K1081
Tregs
Has anyone used or know about the 4" kit from fabtech K1081?
I like the diff relo brackets to maintain CV angles....but Im a little concerned about the word "budget" in the description. I've read good things about fabtech, but there are no reviews on this specific lift......maybe a red flag.
I'm looking at 4" kits. I haven't found many options.
Thanks for any insight.
rattmobbins
Everything Fabtech makes is killer quality. "Budget" for them just means less expensive for folks with mall crawlers (95% of the folks lifting their vehicles anyway). It doesn't mean it's like some crap Rough Country kit or something.
I wouldn't hesitate for a second if you're interested in that kit.
01Konvict
Boats n Hoes
Raleigh/SML
I talked to them about it and it's a very good kit for the height. I would give it a shot
ProTour 67
In an email they stated that the lift on the test truck was 3.5".
My leveling kit is 2.5"
Not sure that the extra 1" is worth it
Did you go a different route?
chiefisaac48
Looking forward to posting pictures of the lift this week, once it shows up in the mail!
Sent from my SAMSUNG-SM-G935A using Tapatalk
T
Tregs
Following.....
Are you installing it yourself?
chiefisaac48
I am going in a different direction. Ordered the kit but it's 3 weeks out for the parts. Fab tech is waiting on ball joints n a arms so I'm going to throw RC 3.5 on it. Will run 275/60/20
rattmobbins
Truck looks good but Rough Country doesn't even begin to compare to the quality of Fabtech stuff.
To each their own I suppose....
TJ2718
Looks REALLY good. What amount of backspacing did you go with? I also want to run 275/60R20 tires on a 3-4 inch lift and don't want to trim anything if it can be avoided.
Joshb0718
Just got the suburban back with the fabtech 4" lift. Was really hoping it would sit level, fabtech said it would and so did the installer, they said give it some break in miles and see if it doesn't settle out some in the rear. Kept the factory 22's and went with nitto g2's 33x12.5
01Konvict
Boats n Hoes
Raleigh/SML
Wow that front end is low! No way that is going to ever settle that far. Get some pics of front end parts so we can see whats going on.
Joshb0718
Here's the pics of the front end. Really wish the front was as high as the rear! But couldn't justify $2k more for 2"
*Edit - would help if I add the photos!
JJ351
CA
Looks like you could just take out that 1" (?) rear spacer.
01Konvict
Boats n Hoes
Raleigh/SML
Pics of front end look great. Everything seems setup correctly and max height without doing full suspension lift. Could you post some pics of the rear now?
Right now my thoughts are to lower rear to match front height but if you don't like that option we could get the zone off-road front end 4" lift kit. That will get it in height with the rear for sure. I'm wondering if some of the rear parts are for the 6" kit or something to make it that much difference.
Joshb0718
The zone kit would that mess with the magnetic suspension? What parts would it use to stack? I have this love kit that was taken off to put this lift on, not sure if could use either of these to lift the front up any more with out over stretching the front suspension
massivespl
I'm not mean, I'm honest.
Michigan
If fabtech said it would sit level and it doesn't I would send them those pictures and tell them it make it sit level. To me that's crazy rake and I wouldn't pay if I wasn't happy. I think that front end needs to be 2-3" higher.
It just looks leveled in the front. Can u measure from ground to fender and someone with a level kit can chime in on what their height is?
Joshb0718
Luckily I took these measurements before I sent it in... 2.5" level kit is what was on it with factory tires.
These measurements are front and rear, before and after
Front: 37.5 to 39.25
Rear: 37.5 to 41.5
Full photo is with level kit on
Drewphil
