Basics on Increasing Horsepower
srs5150
Here's my first attempt at an article for TYF....
In a very general sense, our engines are nothing more than large air pumps. They suck in air (intake), mix it with fuel and spark to generate power in the combustion chamber, burn it, and spit the bad stuff out the (exhaust) tailpipe.
The better our engines breathe (the more air they can suck in) and the more air they can efficiently push out, the more power our engines will make.
Cars (including our trucks) – I use “cars” for short - are mass produced to be nice and efficient. Many government agencies see to it that our cars are produced to be quiet, fuel efficient, and good for the environment. All good stuff for the masses, I would agree.
The stock air box (intake) on mass produced cars is not made for horsepower, it is made with restrictive airways and a basic filter to keep it efficient and quiet. This chokes your engine from a lot of that good horsepower producing air that it needs to roar. Most engines off the assembly line aren’t allowed to roar, that would be un PC, and we can’t have that!
On the opposite end, the exhaust is the same way. Mass produced exhaust manifolds are used because they can be made cheaply, and easy to install (relatively speaking compared to headers). Next, your exhaust needs to push that air through at least one catalytic converter, mufflers and restrictive piping. The “cats” purpose is to get rid of most of the noxious fumes that your exhaust would normally spew into the air. Mufflers quiet the exhaust down and every angle or “turn” in the piping represents a point at which your exhaust is not breathing as well as it could.
Enough talk, let’s build some horsepower!
#1. Intake: So, when building horsepower, I think it is safe to say that most people start with the Intake (tube, not intake manifold). It’s a bolt on that can be done in under an hour and has noticeable results right away. It might not throw you back into your seat any more than it did before, but it will add a noticeable growl when you hit the GO pedal. And we all know from our Honda Civic friends that louder means faster. Oh, no, he did *NOT* just go there, did he? I’m allowed to, I had a hot-rodded Civic in a past life (without the fart tube, mind you). I also have ADD, back to the topic….
Cold Air Intakes (CAI) and ram air intakes simplify the stock air box by replacing it with a simple large diameter tube with a high flow filter on the end of it. Something to keep in mind is that (in addition to just “air”), your engine loves cold, dense air - so be careful which aftermarket intake you select for best results.
#2. Muffler: The easiest mod on the exhaust side is to replace your restrictive (un sexy sounding) stock muffler. Mufflers are relatively inexpensive and a shop can put one on for you in an hour or so. Depending on your selection, you will notice a dramatic sound in tone of your exhaust. This tone may be pleasing or obnoxious. I recommend spending some time on YouTube listening to different mufflers and listening to other trucks. Remember that the same muffler on a big block V8 will not sound the same as it does on a 4 cylinder Honda, so take the source into consideration, as well.
A twist on #2 is a “Cat Back” exhaust system. Here, instead of just doing the muffler, we are also swapping out the restrictive piping from the catalytic converter(s) to the exhaust tip. If you look at stock piping where it bends, it’s usually pinching at the turns. These pinches restrict air flow. If you have heard of the term, “mandrel bends”, this means that when the pipe turns, it does so gradually, without pinching, or changing the diameter of the tube. This maximizes air flow.
#3. Tune: If you’ve done the basic intake and exhaust mods, your engine should be breathing better. Air / fuel mixture is very important to generating horsepower so letting your car’s computer know you’ve changed the game a bit will help go a long way to taking advantage of the horsepower you have already freed up.
That’s the easy stuff, and It should free up horsepower. How much? I’m not going to say because it is so subjective and there are too many variables. Read up on each component to see what kind of gain you can get. Don’t take the manufacturer at their word, check where guys have dyno’d results. The gain from each mod individually might seem slight, but adding them all up together as a system will make for noticeable gains.
This has gotten a bit long winded. I have many more ideas on really taking it up a notch. If you guys feel this is valuable info, let me know and I can do a part two.
Very interesting. I'm sure it clarifies for the novice, and maybe some old heads on here. Keep the knowledge coming Steve. :)
dantheman
Houston
just a note, the stock airbox in these trucks with a high flow filter produces more power than any of the conical filters in the engine bay. hot air = less dense = less power. cooler air (even if only 10 degrees cooler) will produce more power. for these trucks the best setup is the stock airbox with a high flow filter, and a replacement tube that goes from the MAF to the throttle body.
08HoeCD
dantheman is correct.
While the basic information provided by the OP is valid for many vehicles, you won't get much bang for the buck with these recommendations on a late-model Tahoe because the oem airbox and even the muffler are not as restrictive as on many other vehicles. The tune is where you'll see the most results.
dantheman
Houston
some of the reading ive done has suggested that the earlier trucks 00-05 tune has the power enrichment not ever coming in and that MOST of the gains you get are from enabling it. if i recall they have it set to something like you have to be at WOT for 200 seconds before it goes to PE mode. i might be wrong on this as its all 3rd hand knowledge. i havent hooked my hp tuners up to the tahoe yet to tinker with it and see. but picking up 30-40hp off of just adjusting 1 tune value would be pretty rockin lol.
Danny3737
Adding a cold air intake and/or a performance air filter while still using the stock throttle body is going to give you little to no extra HP. The computer without a tune is going to ultimately determine the air flow mixture. That's why when the air filter gets dirty ( to a point ) the drivability and performance stays the same.
adventurenali92
Big Bear Lake, ca
So my apologies if this has been asked before. Bear with me. I'm still new to underhood mods and changing things performance wise. As of right now, I have a spectre CAI, that I got from another member and love it, on my 2006 Denali XL with the LQ4 6.0. Everything else is stock setup. Now, I think a cat is starting to go bad(I think there's 2 right?!) so here's my question, when I have the cats(?) replaced, I want to do a custom exhaust while everything is opened up down there. What's a simple exhaust mod route to go, that will give my truck a nice beefy sound, but not too crazy, maybe a little more kick when I go, but not necessarily have to have this, And what would I need to replace my cats and not break the bank? I also don't really understand the differences in exhaust setups, so any insights you guys have to share on that would also be appreciated!
W8TVI
Traverse City, MI
I'm not sure if the newer GMT800 trucks still are laid out like mine is, but on my Yukon XL, it has two cats (one on each side, that Y into a single pipe once it gets down to the underside of the truck. My mechanic said he can convert it to true dual exhaust by cutting out the Y and running two pipes and mufflers to the back of the truck for about $650 installed.
My dad's truck is plumbed the same way and he had it done. I love the sound, and want to get it done on my truck, but there are other things I should need to fix first before putting $650 into something that doesn't need fixing.
Here is a video of what his sounds like:
Chubbs
Air filters and exhaust systems will not provide any neck-snapping horsepower LOL. I think you are getting a placebo affect from the cash that you are spending. A high dollar exhaust will only make your truck sound different. If you need new catalytic converters then a cat-back exhaust system isn't a bad idea but don't spend a lot of money on that unless you plan to at least have the PCM tuned. A high dollar exhaust will add nothing performance-wise. High flow headers and cat' converters are needed for folks with actual engine mods (stroker/big bore/forced induction/camshaft) and allows that new high volume of intake to be expelled by the engine at the same rate. If you spend $800 for a new sound more power to you but if you are conservative please keep in mind that you only need a high flow exhaust if your intention is to build on your motor.
These trucks are getting old. Soon as you spend 1/2G$$ on something unnecessary, it will need a very necessary 1/2g$ repair so I always have that in mind. Better off putting a cheap cat' on it and have the cash handy when a wheel bearing or Ujoints start to fail.
adventurenali92
Big Bear Lake, ca
So like I said, I'm not looking to go big on power. I also didn't say I was going to spend a ton of money on useless product. I was asking for simple advice. Your reply wasn't very helpful.
Denalis have a pretty decent factory exhaust. Instead of a y-pipe and a single exhaust from there back they have a dual exhaust all the way back to the muffler and the diameter is bigger ( dual 3 " I believe) than Tahoes or standard Yukon's. Best bang for the buck when replacing cats on a Denali is high-flow cats( if possible in CA )and then replace the muffler with something with more flow. If I remember right you'll have a dual in, single out muffler which limits your choices there. I had a merge pipe added to my Denali in front of the muffler so I could go to a single in, single out which opened up my choices. There's nothing really to gain with a cat-back on a Denali except for looks in my opinion. (You do have 2 cats right after the exhaust manifolds but no y- pipe, just dual pipes all the way to the muffler.)
Chubbs
Sorry dude. I got confused by what you were actually wanting to know.
You are wanting suggestions as to how and what you should replace your factory exhaust with, mostly for a better sound, and how/what you should do with the cat'converter should it need replacing? Right?
I'm of the opinion to replace the cat' converter with an aftermarket or OEM of the same type original to the truck. Then you can change the muffler to something of your preference. There are so many different mufflers & so many opinions that it's like asking the regulars @ applebees which beer you should drink. 1 guy may think his Flowmaster50 is the best thing ever while the next guy who bought that had it removed the very next day & changed to a Magnaflow on H-pipe. Borla mufflers with X-pipe has its following. X-pipe & Flowmaster44. These are 2 mufflers instead of I think the 1-muffler system that your truck comes with. I don't know about the 6.0 Denali but there 100-options. My best advice is to not allow the shop tech to make your choice for you or suggest what his preference is; that never works out well. Go in there knowing exactly what you want or with what you have ordered for install only.
You can YouTube "Denali+muffler+flowmaster+borla+6.0" any & all combinations & listen to sound clips of the different setups. You can hit Amazon & Google for catbacks and search until you find a deal that's good for you but performance-wise the cost doesn't justify the means and most setups are designed with either performance/sound/appearance in mind, therefore priced super-high according to that niche market people are shopping in.
You will get more responses & hopefully some sound clips of member exhaust for your options bank but def search around for sound clips. If you have emissions testing where you live, even better to keep the cat' close to stock so there aren't issues with oxygen sensors & check engine lights. The muffler only can be swapped to get a different sound but anything like performance exhuaust and upgrading to larger I.D. Piping would not add a whole lot more to sound or power than a different muffler would, alone. Doing 2 mufflers on a crossover pipe increases the sound for sure but doubles the budget. Economically, a high-flow, high performance system won't do as much for your truck in relation to the cost. You can change the tone and replace the cat' for a decent price & leave it at that. Just know that even a cheap, knockoff cat' converter runs $150, closer to $250 for a single OEM replacement, which is pricey to me and not so much the next guy. A cat-back costs way, way more but doesn't help you as you probably need the cats' anyway, or at least 1. On the other hand, if you find both your converters to be functioning properly a cat-back Magnaflow with the chrome stumpy tips exiting behind the back tires will look amazing on your truck and sound like a dream. Then the $1000 or whatever it is may be worth it to you.
Something like that...
Sorry for coming off like a d!ck earlier.
Denali's are different than the Tahoes and Yukons, it has dual exhaust all the way to the muffler. Your picture there does him no good, and if a spare tire is important then the dual exhaust from the muffler back won't work anyway. I've seen it done on our rigs but it takes a lot of custom work. I've included a couple pics of mine for reference on a Denali. My headers (first picture) are exact copies of what the Denali's have, dual all the way to the muffler and no Y-pipe. The second picture shows where they connect to the stock muffler. There's 2 pipes coming forward from the stock muffler that bolt up to the 2 coming back from the engine. Those pipes are welded to a dual-in, single-out muffler. It's actually a pretty free-flowing system and just needs a bit of upgrading as far as a new muffler goes and high-flow cats if they're approved for your local emissions. A cat-back on a Denali isn't worth much in my opinion.
Chubbs
Hey red! Thanks for following up and providing the specific info on his model. You're good!
I live out here in Dallas where the county has somewhat strict emission regs so yes, it is important to be clear on that subject and understand that aftermarket exhaust not to OE-spec could have negative effects.
BadDaddy2003
