M1Gunner
Gainesville, Fl
I stumbled upon a unicorn today. Journeyed out to the only u pull it close to me and walked in and to my surprise saw a 2500 Silverado! The hood was still attached and propped up all the way open in one piece! My heart sank! **** yes! I finally found my HD hood!!! I pulled it down and...
SYKE! I was bamboozled and left with a broken heart... no HD hood. Damn it. Maybe next time.
mals
Western Mass
Since I've had my Yukon that back HVAC has not worked properly. I tracked it down to what I thought was a bad air blend door actuator. As it it now starting to get hotter, I decided to tackle the project. After watching some videos it seemed pretty straight forward, just removing all the interior trim and panels to actually get at it. Much simpler than getting to the passenger side front actuator that I replaced last year.
Finally got to it, and pulled it out and to my surprise this is what I found:
The shaft came out with the actuator, and appears to be no longer attached to the blend door.
So I guess today, all I did was find out that I have a larger problem to deal with, and the actuator is likely fine.
Has anyone else dealt with a similar problem? I assume I have to pull the whole HVAC unit and split it open to replace the door? Any pointers would be welcome.
EDIT: Quick search turned up this video with my exact problem.
That video looks like you'll be having some fun but like you said at least it's not under the dash. I did the recirc door actuator and that one's 5 times harder than the blend door.
mals
Western Mass
Yeah, at least it's some what accessible. My first thought was to try to epoxy the broken spindle after seeing the break in the video. But I can also get the whole housing for $90 delivered, so if I am going to have to take it apart to try to fix the break, I should probably just replace the unit with a new one rather than having to take it apart a second time when the epoxy lets go.
M1Gunner
Gainesville, Fl
You could even plastic weld it back together in one piece but that new box is definitely a cheap PEACE OF MIND!
Tahoe-01
Got new tires and some new (old) rims before leaving for vacation. Then decided to change rear diff fluid, as she's approaching 100K. Changed fluid and found fluid on garage floor next day. Was brake fluid and found brake line above axle rusted And now leaking. Ordered prebent kit. Installed rear axle lines. Go to bleed right rear caliper, bleeder screw rusted shut. Spent couple hours trying to remove bleeder. Ended up buying new calipers. Bleed right rear and then do left rear. Brake fluid starts leaking from middle of truck. The line from abs module to rear center hose blew a hole . Found video on YouTube where guy shows you how to feed that line in. Got that line in, and bled brakes. We made it to the beach, thanks to the info I found on this site.
Danny3737
View attachment 178679 View attachment 178679 Got new tires and some new (old) rims before leaving for vacation. Then decided to change rear diff fluid, as she's approaching 100K. Changed fluid and found fluid on garage floor next day. Was brake fluid and found brake line above axle rusted And now leaking. Ordered prebent kit. Installed rear axle lines. Go to bleed right rear caliper, bleeder screw rusted shut. Spent couple hours trying to remove bleeder. Ended up buying new calipers. Bleed right rear and then do left rear. Brake fluid starts leaking from middle of truck. The line from abs module to rear center hose blew a hole . Found video on YouTube where guy shows you how to feed that line in. Got that line in, and bled brakes. We made it to the beach, thanks to the info I found on this site.
Love the retro look of the wheels
M1Gunner
Gainesville, Fl
Well, although I didn't get to claim my HD hood today, I did happen to come across a 2003 suburban that had it's stock 6 disc changer in it still. Which I needed the display from since mine was broken in a fit of rage... Long story short. So, I frankensteined my stock radio and presto changeo, display works now.
Also, my steering column cover has been unable to lock down on the left side since my truck was stolen. Well, I finally came across a 03 sierra today that still had its cover intact.
All in all not a bad day. It's the little things.
$10.35
MINIz guy
So over the past two days, I gave the Tahoe the "new" car maintenance it deserved:
- Trans fluid + filter
- Rear brake pads + 1 seized caliper
- Front and rear differential fluid
- Spark plugs
- Greased all Zerk fittings
- Toyed around with the dimmer switch, gauge cluster and rear window regulator
No pretty picture, but here's a screen cap of the vlog style video I'll put together on my YouTube channel
jiggie
Cranked down my keys to see if i noticed any lowering lol. Feels likes its lowered in the front but stupid me forgot to measure before turning them down to see how much i got so we will see. This is my burb with my work truck.
[/URL]
jiggie
[/URL]
MadDogDelpho
Texcellent
My headliner fabric is coming loose from the fiberglass or whatever it is. Any suggestions for a good fabric glue for it?
dantheman
Houston
so we went to fill it up again on saturday and same problem with the pump clicking off.
learn from my mistake and dont think you can just disconnect a few lines while the tank is lowered without disconnecting everything. just take it all the way out the first time and clean the hoses.
wife and i did that sunday. dropped it out, blew out all the lines (and got a LOT of charcoal out again) until they were flowing substantial air out. reinstalled and it filled up like a dream.
what an annoying problem. plus side is i discovered i can now completely remove the gas tank and reinstall in 90 minutes on my back in the driveway.
Where'd you drop it off at?
Just to a regular mechanic. He used to work for GM, and was actually sent to school to learn all the electronic and tech 2 crap. I hope he wasn't bs'ing me! I just hope he can figure it out. I've talked to him quite a few times and he always sounds like he knows what he's talking about. I guess we will see.
3m or permatex in the orange can. Don't do it while the truck sits in the sun. Roof should be cool to the touch. Spray both sides--inner material of headliner and the board itself. Let them tack up, then flatten it down. I use the plastic spatula you use to spread bondo. Works like a charm.
Mountain Rambler
