Tahoe Drop from Autoride to Non
Graystone_OG
NYC
So here's my result. Not sure if my front shocks were bad, but my before measurements were about an inch or so lower than what most start off at. So not sure by looking at the pictures how much this drop is considered. Also want to go lower another inch in the front. Like the rake look more.
Also need to do the free travel mod badly. It rides great, but man when I hit dips on the road, it's a loud bang. Anyone know of a place in NYC that can get this done?
Results:
Before - After
FL: 35" - 33 1/2"
FR: 35 3/4" - 33 1/4"
RL: 37 1/4" - 33 1/4"
RR: 37 1/2" - 33 3/4"
Front:
- McGaughy drop shocks
- McGaughy Spindle
- Belltech Alignment Kit
Back:
- Belltech 5305 Springs at 4in.
- McGaughys drop shocks
- DJM Hardware kit
Still need to install:
- Helper bags
- Spohn Panhard bar
- Free travel mod
- Disable Autoride completely. Pulled fuse for now.
mazdawg(Mikey)
HGIC(head ginger in charge)
Lancaster SC
That looks great, exactly what I just did to mine. I've gotta do the free travel mod and I'm ordering the spohn bar today. Which fuse did you pull? When I first got the Tahoe I replaced the rear shocks with non airride ones and did the resistor trick and it worked. When I finally got around to lowering it I did the resistors in the front but it didn't work
kbuskill
NE. FL.
On my 08 Burb the fuse to pull is in the underhood fuse block and is fuse #58 (square green fuse in upper right corner if you are standing beside the truck reaching over the drivers front fender) it is marked ALS/Comp or ALC/Comp or something like that.
Graystone_OG
Graystone_OG
NYC
So I ended putting back the Autoride shocks in the rear because it was sitting a bit lower in the back and constantly hitting the bumpstops. Haven't done the travel mod, but it rides really good now and only sometimes hits.
Also installed my wheels. Rides really good and just rubs on full turn in the front.
67RS427
Looks great! What size wheels/tires?
67RS427
Thanks. Wheels are 24x10 and tires are 295/35/24.
I kinda wish I went bigger but wanted the extra sidewall for these crappy Michigan roads. Same wheel? From NorCalSS... Mine are 22 x 9 (285/45)
Graystone_OG
Graystone_OG
NYC
I kinda wish I went bigger but wanted the extra sidewall for these crappy Michigan road. Same wheel? From NorCalSS... Mine are 22 x 9 (285/45)
Yeah I believe NorCalSS (Tony) gets the same ones. I live in NYC and the roads are just as crappy. Luckily I'm good at avoiding the crater sized potholes lol. i felt 22" is the standard now and wanted something a bit bigger.
bigrhino
l.e.s manhattan,nyc
