My 5 Alarm Hoe
C
Cattivo
The Concrete Jungle
Damn, been busy.
Nice work
Thanks brother, I still need to gut the entire interior, the carpet repulses me...it sucks taking things apart during the summer. I'll just take my time and wait for a nice cool day
My 6 favorite rules from the academy apply to this build...the 6 P's
Proper
Planning
Prevents
Piss
Poor
Performance
C
Cattivo
The Concrete Jungle
You gotta fix that dented door speaker grill!
Good eye brother...I didn't even realize it was dented:thumbsup:
What's up with you Jerzy drivers lol
Just began the cleaning process on the intake manifold...I poured 2 gallons of simple green and 3 gallons of distilled water into a 5 gallon tire tube test tank and will let it sit for 24 hours to get the initial crud removed
I bought an additional 3 gallons of simple green along with 2 more gallons of distilled water and some toilet brushes to do the final cleaning hopefully this weekend if I can get off from work. Hopefully in the next week or 2 I can install the intake manifold, knock sensors and a few other parts to get the Hoe running great again
Amazon.com: Simple Green 11001CT Clean Building All-Purpose Cleaner Concentrate, 1gal Bottle: Industrial & Scientific
Amazon.com: Lisle 19822 Tire/Tube Test Tank: Automotive
That's some dedication to a clean intake!
Yea I want to swap the steering wheel and the shifter as well..is it hard to swap out? haven't really done any research how to remove it yet
Both are easy. Steering wheel just need to borrow a puller from some place like O'Reiley's after pulling the airbag. The shifter has a torx screw that's got Loctite on it; I used a 1/4" ratchet with the right size torx bit, forget what size it is.
C
Cattivo
The Concrete Jungle
I'll see if the mechanic that services our rigs has a puller I can borrow...the shifter looked like it had some wiring attached to it going into the steering column, I'll have to remove it and see this weekend.
Thanks for the heads up brother
Also found a thread on the removal
How To: Remove and Install New Steering Wheel | Chevy Tahoe Forum | GMC Yukon Forum | Tahoe Z71 | Cadillac Escalade - Tahoe Yukon Forum
brice715
