DD nav in non-dd truck
JKmotorsports
Austin, TX
Here are some pics of the install of a double din Pioneer Avic-D3 in my 01 a while back. I took some pics of the brackets I fabb'ed and the the bezel I trimmed.
There are a couple different ways you can do this. One way is to trim the bezel, plastic weld ABS and re-finish the entire bezel. Another way is the way I did it below. I only wanted to spend one day on the entire install from start to finish so I did it the easier and faster way.
I took the clip brackets from a AI 95-02 GM truck dash kit. They need to be spaced apart 1/2" on both sides of the unit in order to clip back into the dash properly, so I used 1/2" scrap of MDF. I used my digital calipers to take measurements of where to drill the mounting holes and where to place the brackets so it would go into the dash right the first time.
The MDF spacers/mount:
The clips mounted to the spacers:
I removed the entire radio/hvac housing from the dash to make fitting and trimming easier.
Behind the radio, there is a metal bracket that is held in place by two rivets and two screws. The rivets can be drilled out, then the screws can be backed out to remove the bracket to make room for the new unit. Some units will require this bracket to be removed, some won't.
The trim bezel needs to be trimmed in pre-03 models to fit a dd unit. I used my Dremel, asst of files, and finally different grits of paper to trim and round-over the edges of the new opening to match the oem edges. Some people mention using a 03+ bezel, but the problem is that you'll need to reposition the HVAC controls, and the contour along the bottom edge of the bezel won't match up perfectly if you have the full legnth center console that butts up to the dash.
02tahoe
Do you have any pics of that lower monitor center console monitor set-up? I have been thinking of doing that exact same thing for my back-up monitor. I have the remote cassette deck and the cubby hole with a door there. Was thinking there would be some way of using the tape deck connection as an ipod hookup.
JKmotorsports
JKmotorsports
Austin, TX
JKmotorsports
JKmotorsports
Austin, TX
Here's one I did in an 04 Tahoe:
Center console, 8" Pioneer monitor and DVD player:
dec322
B'ham AL
JK, what do you do for a living?
I'm loving the nav! This is something I can show to my wife and she will be all over it! I just changed the radio out in my 95 silverado so those adapters are looking very familiar right now. Good work.
JKmotorsports
JKmotorsports
Austin, TX
Thanks man. I've been installing and working on automotive electronics and custom fabrication for about 17 yrs.
JKmotorsports
JKmotorsports
Austin, TX
how did you get into it?
I've always been into cars, electronics, and making things on my own whenever I could, so I took an electronics and automotive class in school. I worked on all my friends cars in school and a local shop took me in and that's where I started. I learned most of my fab skills from watching more experienced installers and also doing a lot on my own. I did more studying and acquired my MECP 1st Class and ASE A6 automotive electrical certs, and also did some studying in acoustical properties.
Timmy
Brunswick, GA
wow. that's cool. i've wanted to get into the same line, but i can't decide between that or culinary school
02tahoe
Thanks JK. That was exactly what I was looking for.
On a side note you guys need to get the donations set-up. I have no usefull knoweledge to give but sure do get a lot of money saving info off of here!:Handshake:
Big Tap
Houston, TX
Yes, I agree...let's sticky this. This seems to be a common question dating back to the old tf.com site. Nice work on the '04 install JK. That looks really clean.
HMFDZ28
Hunt Sta, NY
What did you use to fill in the sides of the DD?? Is that just more MDF or did you use an ABS plastic? Looks awsome BTW. I had to deal with this in my camaro and well its on the list for the truck.
Big Tap
Houston, TX
He mentioned on the old forum that it is ABS plastic. It's a pretty good looking install.
vtxtexan
