McGaughys 2/3 lowering kit
95escahoe
I'm looking at doing a slight drop found this lowering kit it's 2/3 has rear springs, front spindles, shock extenders, has anyone else run this kit? Any pros or cons?
https://switchsuspension.com/cadillac-escalade-2002-2006-2-3-deluxe-drop-kit-mcgaughys-part-33047/
01ssreda4
Im running the djm setup which is the same except keys in the front and I did not install them but put in ebay spindles instead. It turned out good and rides nice for being lowered.
95escahoe
95escahoe
Did u need to switch out your swaybar endlinks or the stock ones still work?
95escahoe
95escahoe
On the rear yes they have to be swapped.
What brand did you use on that? And I'd do just the springs, keys & shock adjusters but don't want a crappy ride or alignment issues if I don't do the spindles, cause from what I've read some people have no issues others do
CKendrick
