Free Travel Mod How To Guide
charlie4170
You all have helped me a lot with my 2006 Yukon Denali and I hope I can start to give back now. I am doing a major suspension upgrade with Wilwood Big Brakes, Bilstein shocks, NorCalSS Tony's 3-5/6 drop kit, and some other upgrades. When I finish I will do a whole build thread with pns, etc, but right now I am just doing the Free Travel Mod. I haven't found a really clear guide showing what to cut - and this is definitely something I only want to cut once...
Is this the correct piece to cut off? Do you cut the entire thing front to back below the frame rail, or just a section of it? Any advice on modding the bumpstop? Ill post before, during, and after pics once I figure it all out.
Knobz
Santa Cruz, CA
Yup. And then grind the rest so you do t slice your tires or your hand or something crazy ha
And then install some 3/4" pancake bumpstops. I drilled and tapped a hole for mine and then threaded them in.
digitalfiend
Expert Overthinker
San Antonio, TX
I'd like to do a big brake upgrade, but the price of parts completely blows my mind. Where did you get the brakes and how much did they run you?
Like Knobz says, you got the part right. When I did my free travel mod I pulled off my wheels and put the rear of my Tahoe on jack stands...just like the way it looks in your picture. I used a combination of a sawzall and a rotary grinder. The passenger side is pretty easy. The driver side requires care since the gas tank is right there. As long as you look over the area well and take your time you'll be fine. Good luck!
charlie4170
charlie4170
They were a big purchase, but I just got them from Summit. Expensive, but no shipping and handling is nice. Fronts are WIL-140-8992-D (16 inch rotors) and cost $1,999. Rears are WIL-140-9838-D (14 inch rotor) and const $1,849. I'll let you know if it was worth it when I am done.
NORCAL SS
SUV SUSPENSION GURU
Yes I use a sawzall cut below frame and good to go. The bumpstops I ship with the kit fit thru the oem hole thats on the axle pad
digitalfiend
Expert Overthinker
San Antonio, TX
Pricey, but I'm sure it'll be worth it. Pardon the pun...but that's a good investment that'll get you nowhere fast. ;)
What plans do you have that you're upgrading the brakes for? You going to be doing some autocrossing or drag racing?
charlie4170
charlie4170
Maybe down the road. Right now just want the yukon acting like a Corvette :happy107:. Eventually I'll be building up the driveline and want the brakes to handle it.
charlie4170
charlie4170
Last night I did the Free Travel Mod. Attached are two photos with the bracket cut, and one showing why its necessary. I pulled the wheels off and used a Sawzall - worked great. I was originally hoping to do it before pulling the springs, but they started to interfere with the blade, so I ended up removing them half way through. Everyone who warned about getting close to the gas tank is very wise - there is not much room to spare when cutting the drivers side.
Hope the photos help the next guy wanting to do the mod.
08grey
Any blade recommendations for the saws all tony? Length, brand, tooth?
Lentsnh2012
Obviously don't get a blade for wood cutting, but I just picked up some Milwaukee heavy duty blades.
Be careful because the blade gets pitched a lot. Cut it at an angle and have a 8" or longer blade. A 6" blade is just too short to cut the bracket sides at the same time.
NORCAL SS
SUV SUSPENSION GURU
I USE A 9 AND 12 INCH metal cutting dewalt blade. buy 5 or each
popo8
Bout to do the free travel mod finally. When loaded its comin down on the bump stops.
Also... i was wondering. Should the factory air leveling system be able to level out a full trailer or am i expecting 2 much from all that weight.
Sent from my SM-G900P using Tapatalk
TheAutumnWind
Iirc the factory system is good up to 1000 lbs additional weight. You could also add an air ride kit if you require more support for heavy loads. Its pretty cheap.
popo8
U mean like a load leveler kit?
The trailer was 7k fully loaded... so I guess thats why it couldnt lift it.
Dan Acosta
Hello, what bumpstops do you supply? How do I get them? Is it only in kits? If so which others would you recommend. Thanks Dan
popo8
I would also like to know what all is included with this kit, @NORCAL SS
wendal
Dallas
Does anyone know of any shop in Dallas that has done / can do the free travel mod? I've researched it and it's not something I want to take on myself... Thanks in advance!
HeavyHoe03
