Kenny D's Tahoe To Go thread
PG01
Up here to the right
You definitely should have a build thread for your truck. If nothing else, it's cool to go back and look at all you've done. It might surprise you once you've documented it.
Haha-- im still trying to remember what, when and where, so i can finish mine, well bring it up to date anyway
Yes, and I should before there are too many mods to fit in a post that won't challenge y'all's Ritalin. I did a build thread on my S10 documenting pretty much anything notable over the 100,000 miles I owned it. I bought it in '02 with about 9,000 miles and sold it with 109,000 14 months ago. I learned this past Monday that it's for sale again from that buyer (still with 109,000 on it:disgust:) and a guy tracked me down on S10forum to get some details. He read everything in my build thread and learned pretty much everything he needed to know- good and bad. He clearly values the truck being that the title of that thread is "My punching bag" and the first line talks about beating and breaking it. :D
I'll start putting something together to post when I have a couple hours.
PG01
Do it do it do it... get ur nuts checked first tho
PG01
My catch can came the other day and of course, as always, i wasn't there..... I walk into the house later and my fatherinlaw says, you got some packages i put them over there.....all loud and shit.....there were 3-4 packages...i saw them in my garage when i pulled in and I automatically knew i was gonna hear it......she looked at me after his comment and if looks could kill.....shit, i would have been dead years ago.....this time however.....lol... I ordered some hair and nail vitamins crap for her and a few tune up parts for my fil and bil mowers so I automatically said.... that was quick, 'YOUR vitamins and YOUR fathers lawn mower parts are here'..... then i quick went out and hid the catch can......
Kenny D
Kenny D
Crosby, Tx
I'm going today to pick up my supplies for a baffle/filter to complete my can modification so I can prepare for my install but today the wife wants to boil crawfish, so I might get to fidgit with it later.
Kenny D
Kenny D
Crosby, Tx
As promised, here is the installation of the catch can...
I started with purchasing this can off of Ebay.
http://www.ebay.com/itm/151552438280?_trksid=p2057872.m2749.l2649&ssPageName=STRK:MEBIDX:IT
and I could have saved a few dollars because after I received it, I realized that it was probably the same can as the cheaper ones that look just like it, minus the bracket to mount to the passenger side cylinder head. ( which I ended up not using ).
20oz. Coke for size reference. As pictured there was no baffles or anything on the inside.
I removed the aluminum hose fittings, they were metric threads and I tapped the holes out to 3/8" NPT so that I could install brass fittings.
Kenny D
Kenny D
Crosby, Tx
Here is the brass fittings installed, I kept adjusting the depth of the tapping process to get the fittings clocked together and deep enough to hide the threads.
I went to Walmart and got my baffle and filter supplies.
I used the grill topper as a screen/filter housing. By cutting it and a few folds, I created "legs" to hold it up from the bottom.
Kenny D
Kenny D
Crosby, Tx
I cut the scotchbrite to fit and I ended up using 3 layers. The notch is for the down tube on the inlet side of the can. It extended below the filter.
I used some 1/4" hose for the tube as my surplus copper tubing was the wrong diameter to fit the fittings.
Here it is put back together. I ended up changing the bracket when I went to install. I was going to mount it to the brake booster but I decided that it was too close to the exhaust for my liking.
Kenny D
Kenny D
Crosby, Tx
I cut the plastic PCV tubing right at the bend
Picked up 2 pcs of 3/8" hose 4 foot length.
Now I spent several minutes deciding on where I was going to mount it. I ended up with a decision to mount it on the side of the fender over the empty battery tray.
Kenny D
Kenny D
Crosby, Tx
Here are the last few pics.
I used self tapping screws to mount the other bracket to the inner fender.
And here it is all buttoned up.
Kenny D
Kenny D
Crosby, Tx
I am using black tape to keep the hoses organized but I am searching for some of those black plastic heater hose supports that was on my 99 burb. Those would be the perfect look for this application.
It came out really good. What was the purpose for putting the rubber hose on the inside? Just curious. Great job.
Kenny D
Kenny D
Crosby, Tx
To get the incoming air below the filter media. As the other side pulls the vacuum above the filter media. That way it's filtered before returning into the intake.
brice715
