Front Air Ride Kit. Anyone using this????/ Reviews???
SSmurdered
i know u see me
Pittsburgh, PA
i called up airbagit.com. they showed me this kit they have for nbs tahoes that will allow me to keep my 4wd. just wondering if anyone knows anyone that used this setup before?? also i see it comes with torsion keys but the tech said you can take out the torsion bars if you want. what would the difference be????
MOBmentality
Has a $25,000 Punch
the front end is HEAVY.. and leaving torsion bars on will assist the bags in getting it up... which has ALOT of advantages as far as wear and tear and even to some extent ride comfort..
The disadvantage is if you leave them in you can only drop it to the level you have the keys set at
MOBmentality
Has a $25,000 Punch
btw.. mine are out..
And yea.. that setup looks on point.. i PERSONALLY would opt for better bags.. 600psi bags are sick and usually have a bumpstop in them.. and will last forever.. remember.. even if youre at 150psi.. when you hit a bump this load increases for a second.. and on turns.. one side of the truck is heavier than the other.. so over building your ride will make it last longer..
IM running these
http://www.kmwperformance.com/product/XS-7
ANY bag by slam specialties is good.. but i personally would go at LEAST 400psi..
FROM WHAT IVE HEARD.. it actually acts like a shock/spring combo.. since its a stiffer bag and WANTS to be at its stock unaired postion.. it has a tendancy to soften the ride.. and act sorta like a shock
Young28
The Yukon God
ga
It looks like it is weld on. The upper bag bracket that is.
Young28
The Yukon God
ga
Huh, Im interested in this. If it is bolt in then I might have to save and buy it. It looked bolt in because the two top brackets have 3 holes in them.
i was looking at the picture of it with the bag and it looked to be welded in but you could be right. Either way personally i would have it welded on. But thats my opinion.
MOBmentality
Has a $25,000 Punch
If it is a bolt on .. and you dont wanna weld it.. i would def leave my torsion bars in for assistance.. imo
BlizzardX23
Sacramento, California
This seems like it would fight the torsion bars...
This wouldnt be for raising for lowering your truck, this would only help for ride quality...(matching the bags to the torsion bars)
Lets say you de-crank your torsion bars so that your tire is tucking...you'll do damage to your fender while you drive...if you add these though and fill them to raise the front end while you drive, I believe the bags will raise the truck fighting against the torsion bars...meaning not only are you supporting the weight of the front end...but your supporting the pressure of the torsion bar twist as well (since the bolt is adjusted for it to be at its lowest point for when parked or whatever)
MOBmentality
Has a $25,000 Punch
eh... youre not counting on the weight of the truck torquing the torsion bars...
When your truck is sitting on the ground at whatever height the torsion bars are "loaded" meaning if you could look at them they are torqued and actually TRYING to make the truck sits higher than it is.. but just like any spring it sits at the level its capable of holding it at.. like if you jack the front of your truck up at the frame.. and the truck goes up but the wheels stay on the ground.. and the truck looks kinda lifted.. that is where the springs are "unloaded"
So everywhere in the spectrum between "loaded" and "unloaded" the torsion bars are providing X amount of energy to lift the vehicle... with X being greater the harder you push down on the truck.. because of the spring becoming more loaded
and ZERO load/lift... being when the torsion bar is unloaded.. which is about the point where when you jack it up by the frame the wheels come off the ground..
This is why when you replace your keys.. you have to have the front end up and the torsion bar unloaded....
Sooooooo
A bag setup like this will basically use the lift that the torsion bar is already providing..
to help it do its job.. so his bag will need lets say 75 psi.. to do what it takes someone elses 125 (random numbers)
SSmurdered
SSmurdered
i know u see me
Pittsburgh, PA
the upper bag mounts are weld on. $699 from airbagit.com includes everything in the picture. the tech support guy said they sell a real low torsion key so i can tuck the 26s when its aired out with the bars still in.
ItsAdam1
Master Fabricator
Sugar land, Tejas
SSmurdered
SSmurdered
i know u see me
Pittsburgh, PA
FYI stay away from chassis tec or shAIM.. basically they are the dollar store for air ride parts...http://www.fullsizechevy.com/forums/general-discussion/street/137429-chassis-tech-aim-products.html
And btw that kit is nothing new. bags over the upper control arms has been done may times to keep the front half shafts. The only problem is you can't ride it low b/c you can damage the shaft from sever CV angles.
thanks adam, thats the first ive heard about AIM being ******. i didnt really research the company. im gonna have to do some more research on a new place to get airride parts from
ItsAdam1
Master Fabricator
Sugar land, Tejas
Hey no problem I just want you to be informed about them. I never heard of any thing good about them....
FYI: I do carry mostly everything for air ride.......... I need to sign up as a vender over here i have some Viair compressors on sale too...
JasonW4141
