Is it worth buying a GM TECH 2 scanner?
RicanGM
Fountain, Colorado
My 1999 GMC Sierra has automatic door locks, when the truck is running it locks and unlocks when the ignition is off.
I would like to disable that feature and I understand that I need a TECH 2 scanner to do it.
What else is the TECH 2 good for, does it read ABS/Airbags/Transmission's codes?
Matahoe
Military
Grand Rapids, Michigan
I read somewhere that most of the affordable Tech 2's for sale on ebay , etc... are clones. And while they might work for a while. They eventually become unpredictable. They aren't backed by any type of support and if they break for whatever reason then you are out whatever you spent + inconvenience.
I would get ahold of an MDI if you could. I don't have one but from what I gather it's the newest and preferred bidirectional tool in use by GM mechanics today..
http://www.ebay.com/gds/Has-MDI-has...e-GM-guys-take-heed-/10000000173082524/g.html
fiatdale
Houstons Best
Houston
I have both a real and a clone, had the clone for 2+ years. Never an issue with both, and they both function the same.
DenaliEd
MN/IA
Fiatdale, can you read codes for airbag/abs/transmissions with the Tech 2?
Yes. You can also command things like the fuel pump, A/C Compressor, etc to come on for diagnostic purposes, on top of a lot of other things.
DenaliEd
MN/IA
The problem with MDI is you need a subscription, which I think is only available to GM Dealers.
fiatdale
Houstons Best
Houston
You can access any module in the truck with the Tech 2. Newer trucks are a bit different in what you can do with one, but for your year, absolutely no issue.
fiatdale
Houstons Best
Houston
You can pay for a subscription, but it can be pricey. And youd better know what youre doing (with programming a module) or youll F it up big time.
fiatdale
Houstons Best
Houston
Real thing? New? At least a couple grand. As for which clone I have, I don't know. I've had it a few years. I'm pretty sure the clones are all the same
TheAutumnWind
I realize that many people that are actually considering a tech 2 may need it for other purposes... however this allows me to access all modules including trans and abs to diagnose issues. For an individual looking to maintain their personal vehicles I am not sure why you would spend several times as much money.
https://www.amazon.com/gp/product/B00652G4TS/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
BTW I also have a el cheapo blue tooth reader and torque 2 and this is definitely superior.
Eickybobby5050
