Anyone seen a BDS 4" on 2015+ Yukon XL or Suburban?
Suburban13
Has anyone had any experience with BDS's new 4" lift for this generation of GM SUVs? I know it hasn't been out long but I haven't found even the first picture of a vehicle with the 4" installed. Any help would be much appreciated.
01Konvict
Boats n Hoes
Raleigh/SML
Haven't seen any 15+ running this kit but a few 07-14s. I would try to find a 4" CST kit since its no track width increase or go bulletproof 6-8" kit.
Suburban13
Suburban13
Well. I couldn't find anyone anywhere running a 4" BDS so I went out on a limb and ordered one and installed it a week ago.
2017 Yukon XL SLE 4WD
It turned out nice. Excellent build quality and fitment. The front is basically the bds standard 4" box kit. I'm running the bds 2" coil spacers in the rear, rough country shock relocation brackets from their previous generation SUV 3.5" kit to address and maintain the auto level shocks, and I made new linkages for the auto level sensors in the rear.
Glocksub
Your Yukon looks fantastic!!
What size tires are you running in these pics? Can you give us your impressions on ride quality as compared to stock with this lift? Also, can you take a overall height measurement as it sits currently?
01Konvict
Boats n Hoes
Raleigh/SML
Looks great!! That front end could go up to 6" easy with a strut spacer. The rear will need 4" coils from skyjacker to equal the front. Also would get rear wheel spacers to even track width. Get some fender height measurements for us.
Suburban13
Suburban13
The tires are a 295/79r18 COOPER STT PRO. Front fender measurement: 41-1/2", Rear fender 42". The ride is great, angles are flat. 1.5" bora wheel spacers were ordered the week before last, I hope they are getting close.
The lift actually measures around 5" from LCA bolt to New LCA bolt. Like mentioned above, you could very easily run a strut spacer up front.
My understanding is the 4" and 6" are very similar with some of the same components but the 6" has longer struts up front, replacement coils out back with a few additional components to address suspension linkage in the rear.
Over the years I have had several lifted half tons lifted 6"+, regeared, running 37's, with my last truck being a 2500HD LML duramax running a rancho 4" on 37"s. So for the first time in my life I was attempting to run a smaller lift but still functional with a good ride and I am 100% satisfied with the BDS so far.
01Konvict
Boats n Hoes
Raleigh/SML
That's great news! Fender heights are great too. You are correct same 4" to 6" front just longer struts. Rear are a few tweaks but possible. I really think my next Denali will be a 4" on 22x10 billets. I love my 7" that's measures more like 8" with 46" fenders but it doesn't fit in garage or most parking decks. I think the 4" will be more feasible all around for you. My bora spacers took about 2 weeks to arrive. How thick is the front cv spacer?
MichaelSE
2010 2500
Tucson
Looks excellent. I think 3-4" of lift is just right on NNBS and K2XX trucks. Looks like it increased the front track width only minimally, too. Great stance.
Glocksub
How tall is it to the highest point on the roof with this lift installed?
2001 TX Tahoe
I would like to stick with a 4" lift if possible on my 16 Yukon but still run a 35" tire. Do you think a 35x12.5R18 would work with what you have, or do you think the tire would be too wide? I'd prefer not to go up to a 6" kit.
01Konvict
Boats n Hoes
Raleigh/SML
Nope won't fit 35s. The increased track width up front causes issues when trying to clear the larger tire
cbraga
How’s everything been with this kit? I’m getting ready to pull the trigger on this or the Fabtech 4”. Wife’s ride so don’t want it too high, thinking this kit is perfect height. I have a bds 6” on my 2500, quality stuff
Suburban13
Suburban13
I’ve been running it for almost a year about 15k Miles. And like it a lot. Running 35s
sanman28
How tall is this truck? Exact look im going for.....just dunno if it will fit in my garage. My leveled 2500hd on 75’s would barely clear.
AH64Medic
South Carolina
I know its old but I just found this thread. I keep hearing about different suspensions on these trucks (autolevel?), how do I know what mine has? It's a 2017 Yukon XL SLT 4x4 ..also any other cheaper (but quality) lift kits or other options available to get this amount of lift? This truck looks awesome if love to get the same look .
Bryingram4
San Diego CA
View attachment 80335 View attachment 80334 View attachment 80333 Well. I couldn't find anyone anywhere running a 4" BDS so I went out on a limb and ordered one and installed it a week ago.
Could you please explain what you did for the new linkage for auto level and please take a few pictures?? I need to do this on my Yukon and would really appreciate your help. Thank you!!!
Bryingram4
San Diego CA
Repost. Can you please explain & send a photo of the new rear auto-level link? Thank you very much!!!
Warzilla
Hey there, I just put this 4inch BDS kit on my 2013 Suburban. I had the same questions about the GM suspension on the rear of my vehicle as there are several versions. Auto Leveling rear shocks are different the the GM Autoride suspension. Autoride is a no-go with this BDS kit. The auto leveling shocks on the other hand can be replaced with the shocks included in the kit. From what I’ve researched this holds true for Suburbans and Yukon XL’s. Here is a link describing the different GM suspensions: https://www.suncoreindustries.com/product/21011/identifying-and-diagnosing-z55-autoride-suspensions. You can locate your vehicles RPO code in the glovebox. Mine was a ZW7. Hope this helps.
Drewphil
