jarydM
Lost in the Woods
Tennessee
Gearing up for a big weekend of replacing Radio, and paint matching some body panels, as well as installing the Esky vent caps.
Update on the intake, my gas mileage has improved a little over 1mpg (using mileage/fuel fill method) which is nice. Its hard not to get into it too much though. "raced" a new Challenger R/T last night on a semi rainy road, and kept pace with him to 65, before I let off :driver:. He immediately got off the highway.
Truck is running like a top, got some other parts on order (intake gasket, head gaskets, knock sensors, new grommets etc) for another weekend down the road.
Goodinblack
I Like Tacos
Dirty South
Nominations for April 2017 Truck of the Month.
http://www.tahoeyukonforum.com/thre...ed-by-gotrinova-com-detailing-products.91728/
Sponsored by GoTriNova Detailing Products.
95escahoe
I thought it was interesting that left and right are different despite them being the same length. Different curvatures I guess?
Ya ones A ones B? I forget, they work great
TheAutumnWind
The Osram D1R bulbs came today, the headlights should be here tomorrow
You are going to like them a lot.
Huge improvement over my worn out osrams and the 5000k kensuns.
Don't be too concerned about the "up to 6000k" they aren't aftermarket blue, more like high end mercedes oem white.
95escahoe
That's good to hear, that's a good color
jaywoo65
Cabot, AR
Because everyone likes pics, here are a few of the Pitman arm/idler arm/idler link arm install I did today. And a couple of notes from what I learned doing it.
MMMMMM... new stuff!!!
You can do this job without pulling the sway bar but dang it's much easier getting to everything without that bar in the way.
Old and new idler arm and idler link arm. It's easiest to pull them as a combo instead of trying to separate them on the truck. Besides, I ordered both pieces new so what the heck. The lower bolt holding the idler link arm is REALLY REALLY close to the AC tensioner pulley.
The Pitman arm was more of a pain. I watched a couple youtube videos on this and people said to take the steering box out. I really wasn't wating to open up the power steering lines so upon further review, I decided to remove the upper two steering box bolts and loosen the lowest bolt. I was then able to rotate up the steering box and get my pitman arm puller on it (there's a frame piece in the way). So hooking the pitman arm puller onto it along with an impact driver and a BFH got the pitman arm off. OH!! And a trip to Home Depot, because I'm stupid and didn't have frickin 32mm wrench to take the jam nut off of the gear box.
So, upon reassembly I made the mistake of putting the steering arm back on the pitman arm and idler arm before I pout the bolts back in the steering box. Don't do that. Makes it much harder to line up the steering box. Then installed the sway bar.
I also took the time to do about an 1/8th turn adjustment of the steering gear box. It drives so much better now. No play at all. Next up will be new tie rod end links. No play but the dust boots are crappy.
HiHoeSilver
Away!
Chicago
Gteat write up, good tips!
wwiizz
