TheAutumnWind
I'm lowered 2 inches in the front with Belltech drop spindles and I need new jounce stops. I DO NOT want my front end raised up cause mine finally sits like I like it. The factory stops are 2 7/8 and those in your pics are 2. So what to do?
Have you adjusted the torsion bars at all? If not use stock ones. Worst case scenario you trim 1/2 or something.these things are foam rubber you could trim them with a dull steakknife.
BADRIDES
Torsion bars have not been touched. I like the look of the 2 inch ones but dont want to be too short but the stock ones seem to be a tad too long and then you have to trim those depending on if it raises you up or not which I dont mind doing.
YukonXL04
The Riverboat
Arlington, TX
Well... Went to a kids birthday party last weekend at the mall. Came outside to find someone broke into my yukon and stolet my pioneer double din. Broke the lid off my console, and jacked up my ignition. Not entirely sure how they got in though.
Looks like the tried to pop the door lock out but didn't work cause it's only pushed in at the bottom about 1/8th" top of lock still fine. Door handle is fine.
So today I get to fix the ignition. New double din ordered, and already fixed the console.
Fuken scumbags!!! Pisses me off.
jarydM
Lost in the Woods
Tennessee
******, I don't get why people do shit like that.
Why I keep insurance, but damn. With I could dole out some justice on em.
I put those Jimmy jamerz, o whatever they're called, on all 4 doors.
YukonXL04
The Riverboat
Arlington, TX
Yea I'm gonna put them on the front. Also have a nice 2 way paging alarm to put in. Heck that's been sitting in a cabinet in my garage for 2 years lol. Just haven't felt like spending the time to wire it all up.
Blackie
SoCal
Fixed the stupid rear blend door and actuator. The door broke so I epoxied it back together. The actuator had too much buildup of the petroleum jelly on the contacts so I cleaned them off. Getting hot here in California and needed the rear A/C working!
W8TVI
Traverse City, MI
Just bought a set of DL3 mirrors, and found the 2002 Esky power fold dash switch for $28!
Now hopefully everything works on everything (everything but the power fold was tested by the seller).
New project incoming!
I plan on taking the 2002 Esky switch out of its trim piece, and tap the points where the stock button connects to and run some wires for a "remote switch" on one of the blanks by the radio.
Looks like you can raise it up 1/2" and it will be level. That should make it ride better, get the jounce stops a little relief, and you won't need an alignment. That's what I would do anyway.
Ok, guess that's the plan then. I don't need that special tool do I? I can just use a regular ratchet?
wwiizz
