timken or moog?
cmc76
had a grinding noise, front passenger. Jacked it up, lots of play in the hub. Timken or Moog?
any reasons why, besides price?
timken
cmc76
cmc76
the shop that services all our work trucks was able to get it in right away. I asked him to get the timken, he said he will try.
Perfect timing though, as i made the u turn to pull into his shop, i felt a pop and it started howling something nasty.
What is surprising, i havent had a long lead up of symptoms. got some slight grind no more than 2 days ago.
Yeah, it can happen quickly once it starts happening. Glad you're able to get it in.
mattbta
Frisco, TX
I've got two timken's ready to put on tonight. They sure are purdy!
I've got two, also, to put on either this weekend or next along with a quick brake job.
cmc76
cmc76
the shop called, timken installed. Its amazing how fast it can be with the right tools and experience.
I dont currently have a garage, in the design phase. If i had to do it at home, would have been in the gravel and a whole lot of swearing. Assuming the rain held off.
* turned out, the timken was for their own shop truck. His supplier didnt have any on hand. good dude.
95escahoe
Timken hands down there the best out there put these on mine a few weeks back
cmc76
cmc76
would have done it myself if i had a spot. Literally uneven mud, gravel etc. Should be excavating and pouring the slab for a building in the next few weeks. Then i will have a flat surface at least.
dantheman
Houston
yea i think it took me all of 90 minutes to change the front brakes (rotors and pads) and swap the drivers side wheel bearing on mine.
Drewphil
