Anyone switch out their 26 gallon fuel tank to the 37 gallon one in the Yukon 2500
Ridculous
Tulsa OK
Hey folks I am wondering if anyone has upgraded their 2005 Yukon SLT / LT or Denali's fuel tank from the stock 26 gallons to the Yukon 2500 37 gallon tank? Since upgrading my 6.0 to a 6.7 (408 ci) I have lost about 1-2 mpg and want to increase my driving range...since I'm not going to go any slower the only other way I was going to extend my driving range was to install a bigger tank. Given that the difference between the 1500 and 2500 is in the suspension, brakes and engine (8.1) I was hoping this would be doable without major surgery. Any advice would be great thanks!
subieworx
I wonder more about the wheel base length and having room to put the tank in a short wheel base vehicle. I would love to do this as well as it would be great for towing.
Ridculous
Ridculous
Tulsa OK
I have the xl version so I will let you know. I asked the local gmc dealer service manager about it
scoobyxj
Really doubt it'd fit in a short wheel base (I know you said you have an XL), and I'm pretty damn sure the frame is thicker, or taller on the 2500.
JakeO625
I have a 2003 yukon denali xl and it has a 37 gallon tank in it so I imagine the swap is possible. Mine came factory with it.
Ridculous
Ridculous
Tulsa OK
Ok so while the 4L80e was being installed I snapped some pictures of the 26 gallon tank in my 2005 Yukon Denali XL. Have no idea how long or wide the 37 gallon tank is but it would be a pretty tight fit. Take a look
Ridculous
Ridculous
Tulsa OK
Not alot of room underneath...I am hoping the 36 gallon tank is a bit taller (thicker) then the 26...
#1taho
5150TAHO
niagara falls ont
I would say the 37 gallon tank is longer. In the 90s trucks that's how it was.
I think it won't fit but I am hoping it will. It may hit the back axle
Ridculous
Ridculous
Tulsa OK
Yes alot of $$$$. Plan your budget then add in another 40% on top of it
Ridculous
Ridculous
Tulsa OK
Oh the dealer said no go on the fuel swap....but I don't necessarily believe it. Going to look for another option
Drewphil
