Losing 50 miles per tank on mileage - help!
DjLarroc
Hey guys, new here but was a member of TF.
Got a 2000 Tahoe 4x4, 5.3. 184k. Runs like a champ, but in the last month or so, the mileage has gotten terrible. I haven't noticed anything different about the truck. Normally I'd get about 300-315 per tank, and fill up would be about 21 gallons (15mpg). My last fill up (yesterday), I only got 260 on about 20 gallons (13mpg). My last 2 fill ups prior, were about the same. Slightly better.
The truck does have a hesitation on acceleration. If I step on gas more, it does nothing. Only way it goes away is if I let off gas, and slightly try to accelerate. Sometimes it catches, sometimes it keeps doing it until it feels like accelerating (Injectors?). It has always done this though.
Any advice appreciated. TIA.
Copper&Black
I would start with a through visual inspection of the injectors. Replace the inline fuel filter, and run a bottle or two of fuel system cleaner. Then run your numbers again to see if it improved. Have you hooked it up to any computer to see what codes you might be getting?
BlueTahoe2001
Charlotte, NC
Run some Sea-Foam through maybe 2 tanks of gas, Replace the fuel filter, Plugs, and Wires.
See what your results are after you do this and then go from there if it doesn't seem to get better.
D
DjLarroc
Thanks for the quick replies guys!
I did new plugs (OE) at 177k. Ran seafoam around 180k.
No CE codes. Will anything come up anyway?
I'll replace the fuel filter. Only recent work, was oil pump went out. Got that fixed. Took on a road trip and avg'd about 18MPG on that trip. Best I've gotten. Then, now, this crappy mileage.
DenaliAK
Colder than you
Alaska
Where do you live and are they adding ethanol or any other winter additives to the fuel? Do you have winter tires on now, which because of their design tend to be less efficient? Is it cold and do you autostart or otherwise warm up the truck? That one kills my winter mileage...warming up the car. Tire pressure ok?
Just a couple of other ideas....
Rivieraracing
Sounds like your cats are crapping out or plugged up, when mine in my Blazer finally plugged up, the more I stepped on the gas the slower it actually went. Try tapping on them and see if you hear anything loose or rattling around in there. Does you exhaust sound any different, kinda like it is breathing through a scuba snorkel? Decrease in exhaust flow out of the tailpipe? Truck running any warmer than normal?
yukonjacks
A Vegitative State
The Confluence
Are you letting your truck idle longer during the colder mornings, no offense but winters are notorious to drag down gas milage from crap you may over look. Also your truck has to run harder due to the viscocity of the oil when its cold
sparg93
Expedition Tahoe
NJ
other than oil pump, any other changes you have made to you rig?
If none of the changes the gents above mentioned work, one item might be the fuel pump itself...just my thought when u said that when you pressed ******* the accelerator, not too much happened.
D
DjLarroc
Air filter?
It's not new, but I checked it and it's clean.
I'm in CO. No new additives as far as I know. Usually fill up at the same place. I have the same tires as before. They are an aggressive all season. No auto start. Tire pressure is good.
It's running pretty normal. I'll check the cats. You may be right. How much were they? Just curious.
No long idles. Everything is the same which is why I'm stumped. I've had to use the 4WD, but it's been so minimal, I'm very doubtful that's the culprit.
No other changes. Anyway I can tell it's the fuel pump? The truck starts right away every time. Although I know bad fuel pumps are common in these trucks right?
So does everyone think I should start w/the injectors? When I step on the accelerator (and this happens about everytime I drive the truck - usually at the beginning) the truck stalls bad. It moves along better accelerating very slightly until I can tell, it's normal.
D
DjLarroc
Ok. So maybe what I'll do first is run a bottle of heat through it to kill any moisture in there. Last winter this did not happen, and I would have noticed this for sure. Plus I track my mileage and maintenance on mycarprojects.net so I have it all logged since I bought it last November.
possumsquisher
Make sure to check the oxygen sensors. If they are not cycling properly it will kill your gas milage. Mine dropped from 17 to 13 with no check engine light. Found out both rear sensors were slow.
Eagle
Thansk for all the help -STAFF!
EL PASO, TX
that is PROBABLY what is killing mine... averaging about 11.8-12.4 no matter how aggressive or nice I drive.
R
Redraider yukon
New member
Just wanted to introduce myself. Joined last week and glad i found you guys. I've always been a truck guy(F-150), but after transmission problems for a second time in 3-4 yrs I bought a family members 01 Yukon 4x4 SLT 3 months ago. Looking forward to catching up on some of the posts on here and plan on putting wheels on my yukon next year. From some of the pics I've seen I might just check out pics and not post one of mine until i get it up to par. You guys have some nice looking wheels.
D
DjLarroc
Update
Hey guys, I'm a firm believer of updating, even if the problem/fix was minimal.
I checked the air filter, and hoses, and all seemed good.
I ran a 1/2 bottle of heat (yellow bottle) in my last 3/4 tank. Within the first 100 miles, the hesitation went away, and my last tank reached 305 miles before the low fuel lamp turned on. Almost back to normal. I only ran a half bottle.
I just poured a full bottle into a full tank, but it looks like things should be back to normal. Musta just been bad winter gas as mentioned, or had water in the tank/lines. :happy107:
ActSwedish
Stockholm/Sweden
Congrats that it´s running better. What is heat? is it like something that takes away the water or some other additive?
CKendrick
