Slap, Slap!
S1nemesis1s
Hey Guys,
So I just installed a new wiper motor, transmission, and arms on my 2004 Tahoe. All parts matched up like the old one. However, now I am the wipers are slapping the cowl! They return to where I set them when off, but they sweep through and hit the cowl while operating. Any ideas?
cmc76
i have never taken them off, but arent the arms on a spline? i would think you could pull them both off and move over a tooth?
S1nemesis1s
S1nemesis1s
Its weird, because they go back to their resting spot but actually swing down then up. I am unsure here. This looked pretty straightforward, There is something I am not doing right or something is up with my parts.
sumo
dn ʇǝƃ ʇuɐɔ & llǝɟ ı
rhode island
I've seen this many times before. Usually worn wiper transmission linkage or worn wiper splines on motor and or wiper arms. Usually happens when people try to clean heavy snow without brushing snow off windshields. You can try removing the wiper arms and move the wiper arms so they sit higher on the windshield
S1nemesis1s
S1nemesis1s
What is strange is that its all new parts! Yikes! I got tired of fooling with it and I sent the aftermarket transmission back to Amazon.
I going to install my old stuff, grease it up a bit, and see where we are at. I am hoping that I can just install the original parts and be done with it. It has had a motor replaced in the past, I can tell from the crushed top on the bushing from pliers.
I will just keep the new motor for an emergency.
I was rushed through this by my wife, she needed in the garage for a couple of days, (sorting clothes) and that was my first mistake, I should have just waited until I had the time to do this properly. I ended up breaking a couple of tabs on the plastic piece that goes over the drivers side hood hinge, and I lost my damn boot covers for the splines!
At this point...I am just ready to get it all back together and have wipers again. I hope I can get these arms to work, my old ones were rusty and crappy. This is a repair I am just going to try to get back to what I had before and tackle it when it really breaks. Right now I will say i "serviced it."
S1nemesis1s
S1nemesis1s
Reporting back!
So it looks like my aftermarket transmission was the problem. I installed my new motor, cleaned everything, lubed all the joints, and installed the new arms. They are AWESOME! Zero noise and they work so well now!
I am concerned though, I lost the "boot," "dust cover," off of one of the wipers, the passenger side that goes into the cowl. I am hoping its not a huge deal.
Otherwise, she is on the road again!
S1nemesis1s
S1nemesis1s
Yay I was right. Can you get a refund? As far as the boot, no
Yes, thank you :) I literally was 1 day under the wire for being able to return the linkage, worked out great! So I should not worry about that boot too much, that is good to know. The wiper work great now!
Drewphil
