Fosscore
Got blue LEDs in the steering wheel controls as half were not working and replaced the peeling SEEK/VOL button.
1992rs
OR
Used the leftover 1/0 gauge I had from my camaros battery relocation to do the big three. Used a stinger fuse box off the battery to be safe and wrapped it all in black nylon techflex because lime greens just too much for the Denali lol
So far haven't noticed too much of a difference, but apparently the people on gmfs have noticed a 1-2 mpg increase so I'll be on the watch for that.
jarydM
Lost in the Woods
Tennessee
Agreed, but it would be a major undertaking both in initial execution and in maintenance. I can't think of a simple way to do it within the forum structure, and almost think a wiki that linked back to specific posts or whole threads may be the best approach, and could be cooperatively built over time.
Definitely an undertaking, but I think it would be something good for all of us.
a Wiki would be awesome, if it would link to the right place. Maybe something worth looking into. or just a new post disguised as a wiki with links built in.
mals
Western Mass
Very clean install. This one is getting bookmarked.
I've been seeing this "big 3" mod talked about. What is it and what does it do?
Fosscore
I'm sure you guys have been in the NBS Tech Info section of the Forum which has pages of the How-To links
Here is the jump to that master thread page.
http://www.tahoeyukonforum.com/forums/tech-info.54/
Your master idea compilation is an excellent idea as there is ridiculous knowledge, how to's, mods and info contained herein. From the basic info about the NBS model to detailed repair and maintenance info.
Your contributions are appreciated.
1992rs
OR
In short, it improves the electrical efficiency of your system. You add either 4 or 0 gauge wiring to the following:
- Battery (+) ----> alternator (recommended to put a fusible link between these)
- Battery (-) ----> chassis (I used my bumper support bracket)
- Engine block ----> chassis (I used one of the alternator bracket bolts and connected it to the factory firewall ground bolt where the braided wire is)
It's common to do this when people have big power hungry systems in their cars and suffer from headlight dim. The thicker gauge wire has less resistance so it provides less voltage drop. It also helps little things like making windows roll up faster when you roll up all four at once. I did it because I'm slowly building a system and wanted to get it over with and my shit would barely start when it was below freezing and snowing.
Appreciate it. PM me if you have questions
bottomline2000
Dallas, TX
What did you use to add the wiring to the battery side post? I dont have a bolt to secure any extra wiring down. I may have to switch to a side post only battery and get rid of my top Mount connections..
Nice. Thank you.
MadDogDelpho
Texcellent
Converted all my interior lights to LEDs and it looks great. Unfortunately the kit didn't come with enough lights to do the puddle lights or the plate lights, so I'll have to get extra lights for that.
1992rs
OR
I use these: http://www.oreillyauto.com/site/c/d...=Search_N0365_1504401_2529&pt=N0365&ppt=C0005
I dont know how you have your top post mounted but you can run something like this if all you have is a top post. That way it gives you multiple spots to mount things. http://www.knukonceptz.com/mobile-audio/battery-terminals/sp/bassik-positive-battery-terminal/
Or if you wanna be a baller and have both top and side posts you can go as far as this and just use the top posts for big three, amp wires, etc..
http://www.knukonceptz.com/mobile-audio/battery-terminals/sp/konfused-positive-battery-terminal/
A dual post battery is really the best solution for us. I plan to buy one and use a combo of the first and third when I get a system hooked up. Side posts for oem wires, my HID's, and small accessories. Top posts for my big three and amps.
I called two places to price out powder coating for the 22's. One place wants $600 another guy wants $900! Way outta my price range and I think the second guy was inhaling his powder coating!
Countryboy07
Couple years back I was quoted $65 per wheel for my 18 x 9's.
MadDogDelpho
Texcellent
Unfortunately I think so. It was either have license plate lights or have front footwell lights. And I'd rather have all the interior lights be the same than have the plate lights be nice but still have 2 different colors with the interior lights, y'know?
wwiizz
