My dual battery writeup...
JonnyTahoe
Minneapolis
This is a 2000 Tahoe not sure what these would be for.
View attachment 72857 View attachment 72857
Cattivo
The Concrete Jungle
Great write up brother. I'm doing something similar to the back of my hoe...wouldn't it have been a lot easier to just install an inverter?
Martinjmpr
Martinjmpr
Littleton, Co
Oh hell no. First of all, an inverter would not add any electrical capacity - the problem I had was that running a fridge was draining my battery of power when the truck wasn't running (like when we were at a campsite for 3 days.)
Second, an inverter is a TERRIBLE way of using power. Wasteful and inefficient. Trying to run 120v AC appliances on a 12v DC system sucks enormous amounts of power, way more than is needed. Much better to use dedicated 12v appliances (my fridge actually has a built in AC-to-DC inverter and will run on either 12vDC or 120vAC.)
My setup adds 68 amp hours of power (given that you generally don't want to discharge a battery - even a deep cycle battery - more than 50%, that means that effectively I have 34AH of usable power.) My fridge has a max draw of about 4.5ah but that's only while the compressor is running at max capacity - realistically 1ah or less is probably the average load.
Even better, since the "house" battery (i.e. the added battery) is not connected to the starter battery, then even in a worse-case scenario where my house battery discharges completely, I can still start the truck with the starter battery.
Inverters are OK if you are only using them while the engine is running, but they are absolutely useless if you intend to run high-draw components when the engine is off.
I should also point out that I have a 100 watt solar panel that I will be connecting to the house battery to keep it "topped off" when we are camping. I'm still working on that setup (though I've used it successfully to keep the starter battery topped off as well as the 12v deep cycle battery in our trailer, so I know it works.)
mals
Western Mass
I just bought this inverter, i'll install it once it gets warmer out along with a new battery
5000 Watt Power Inverter 12 volt DC by AIMS
What @Martinjmpr said, plus be aware that the the inverter you linked to is a modified sine wave inverter. These are fine for running motors, lights, and other similar tools, but should not be used with sensitive electronics like computers or anything that charges batteries.
Cattivo
The Concrete Jungle
I'll most likely only use it for power tools if there's no power nearby and need to work on the truck...and of course my favorite use for it will be for tailgating :cheers:
Martinjmpr
Martinjmpr
Littleton, Co
Just make sure you know how many amps you are drawing, either that or keep your engine running while you're using it. Also anything that makes heat will draw an enormous amount of power.
BigDaddy13440
Rome, NY
I learned the hard way that I can't even leave my inverter ON without the truck running. I can run my stereo for about 5 hours straight (as long as I turn off the subs), and it'll start up with no problem. I mistakenly left the inverter on while working for about 3 hrs, not enough juice left in the battery to crank over. So I had to go to AutoZone and buy a second pair of jumper cables (main pair at home, in the garage:banghead::banghead::banghead:). Now have a pair in the wife's truck, and in mine.
I primarily use it to plug in the chargers for my Ryobi 18V Lithium batteries. 30 minutes for a full charge, turn it on when I'm done at the jobsite for the day, fully charged by the time I get home - never have to worry about not having a fresh battery! Of course, I have seven of them....:sunot:
Martinjmpr
Martinjmpr
Littleton, Co
Yep, the other issue with inverters is that they are drawing power even when they're not powering anything themselves. That's why it's usually preferable to run 12vDC accessories rather than trying to use 120vAC and running them through an inverter.
donmorgan1966
Crossposted from Expedition Portal (http://www.expeditionportal.com)
So after several months of thinking and planning and pestering other board members (Thanks, Jelorian!) my dual battery install is done. Well, SORT OF done. Done in the sense that the 2nd battery is installed and seems to be charging. I still need to "clean up" the engine compartment (no, I'm not driving it with all these wires all over the place, I have a separate DD!) I also have to get a power source to the interior of the truck and then put in my dedicated 12v power outlet for the fridge, and will probably run another power wire for my 2m HAM radio.
Anyway, I thought some of you with GMT-800 vehicles might like to see my writeup, so here it is. Nothing too fancy, I basically copied Jelorian's but I did just a few things differently.
On some dual battery setups, the hard part is figuring out where you're going to shoehorn in a 2nd battery in an already crowded engine compartment. But, since the GMT-800 trucks had an option for a 2nd battery on the passenger side near the firewall, that part is easy: You just get the factory battery tray and replace the brace on the fender with the battery tray. It's a straight bolt on.
As you can see from the photo, I put the crescent-shaped hood brace back on because I wasn't putting the battery in right away (I got the tray back in June or July.) In order to put the battery on, though, that brace has to come off.
Next I had to figure out where and how to mount the isolator. I went with the same 200a "Stinger" isolator that Jelorian used. I was nervous about drilling into the firewall (because I wasn't sure what was behind it - didn't want to hit a heater line or something) but it was no big deal. Instead of using sheet metal screws (which I was worried would loosen), I went with "jack nuts." For those who have never used jack nuts, they're pretty cool. Basically it's similar to the idea of a molly bolt, you drill a hole, then put the jack nut into the hole, then use a special tool to expand the back of the jack nut which then grips the sheet metal. In essence, it puts a nut on the "blind" side of a piece of sheet metal that you can then put an actual screw or bolt into.
Located where I wanted the holes and drilled for the jack nuts:
Jack nuts in place:
Once the jack nuts were in, I bolted in the isolator using machine screws, washers and lock washers.
Once that was done I turned to my cables. I got 20' of 2AWG welding cable from a local welding shop and some large ring terminal ends. I don't have shrink wrap, a soldering gun or any fancy crimping tools...but I DO have a bench vise!!
I'll bet I use the vise more than any other tool I have! It's awesome for having a 'second set of hand' to hold onto things while I work on them. Got the ends crimped on...
Then sealed with electrical tape...
I know some of you use shrink wrap but for me the "redneck" style tape will work.
My biggest expense (and the one thing that kept me from getting this done months ago) was sourcing the battery. I went with this from the local Batteries + Bulbs outlet.
It's a group 34/78 (i.e. it has both side AND top terminals) deep cycle AGM, rated at 68ah. That's quite a bit more than my starter battery (also an AGM) which is rated at 55ah. It was very expensive (about $280 OTD) and while I was sorely tempted to go with a cheaper battery just to get this done, I thought, "No, I only want to do this ONCE." The battery fit perfectly in the tray.
On the "starter battery" side instead of using a quick-release (as Jelorian did) to get enough extension to reach the positive side terminal (it's kind of buried in there!) I used a marine terminal on the top terminal of my 34/78 starter battery.
The reason I went with this was simple: Because I already had the marine terminal adapter. The only 'downside' of this is that I did have to remove the metal rod brace that runs diagonally across the top of the battery (GMT - 800 owners will know what I'm talking about.) I don't really know that the brace is even necessary. If I decide to use an extended side terminal adapter as Jelorian did, I can put the brace back but for now I think this works.
You can also see that I wrapped the positive cable in red wire loom. Not really "needed" as the 2awg wire has a very thick insulator, but I wanted to be able to tell + from - at a glance and since the cables were all black, this was the best way to do it. It also lessens wear and tear on the cable.
Hookups on the "house battery" side. The Stinger has 2 large posts that are for the positive connections to each battery and two small posts. One of the small posts goes to ground and the other goes to a powered circuit, to open and close the switch. It doesn't matter which one of the small terminals is used for ground and which one for the switch, they're interchangeable. In this photo I've connected the + cables but not the - or the switch to the Stinger. As you can see I used the Blue Sea side terminal fuse holder, just like Jelorian. I used 150a fuses on both ends.
Final setup of the house battery with all wires connected. If I was more picky I might have used black wire for the ground connection and red for the power connection, but I had a bunch of yellow so that's what I used. View attachment 173907
A few notes about this: I used an extended side terminal bolt on the negative side, that had another bolt on the end of it. Both the negative/ground battery connection and the negative wire to the Stinger are attached to the outer bolt. The negative battery cable is also a 2awg welding cable with a crimp-on ring, the only difference is I wrapped it in black wire loom rather than red. The yellow wire that runs from the negative terminal to the stinger uses ring connectors on both ends. The negative attaches to the small post closest to the front of the vehicle (closest to me in the photo) and the yellow wire that runs from the rear small post on the Stinger is the power wire for the switch that runs to the fuse block.
You can see that I routed the large negative battery cable (black wire loom) underneath the Stinger....
...and connected it to the same bolt as the chassis grounding strap behind the engine. The yellow wire is the power wire that goes to the fuse box.
And here's the fuse box (sorry for the fuzzy photo, it was getting dark and my camera was having a hard time focusing.)
I used an add-a-circuit and went into the same 10a ignition fuse slot that Jelorian used on his. Wire is routed underneath the fusebox.
After I got everything buttoned up and bolted down, I started the truck. Measured 14.5 volts at the starter battery and about 14.25 at the house battery - I'm assuming that means the system is working as the house battery appears to be receiving a charge?
So do just not use the firewall to fender bracket any longer? I'm finding it won't fit with any battery I can fit on the tray.. itsca heavy bracket I'm sure it's there for a reason.
Ralph Turner
