01 Tahoe Fog Light Install Question
huffster329
Fort Eustis, VA
So my Tahoe did not come with factory fogs. I'm going to be making my own harness and wiring into the under-hood fuse box. I'm not really interested in the 4-HI mod, I want a factory fog light setup. I have the OEM switch, fog lights, relay, pigtails from LMC truck, black & red 18ga. wire, and wire loom... I think I have everything but the connector for the fuse box. There is a guy on YouTube that did a how-to on a 03-06 Silverado and he says all you need is a metri pack 280 female terminal to plug into the fuse box. Something like this: http://www.ebay.com/itm/Lot-of-10-1...678607?hash=item2ec06a29cf:g:p0cAAOxy0bRTDRK-
Am I on the right track? Has anyone done this themselves? Any help is appreciated.
05Single
afraid of the dark
It's been done many times on many vehicles, but I personally usually just tap into something. i.e. Ignition , headlight harness, or independent to the battery.
And I can still make it look factory.
Fuse box is great too. 03 has a different electrical system than an 01, but it sounds like the same concept.
05Single
afraid of the dark
@ScottyBoy would be able to point you in the right direction.
I think @Fosscore added fogs to his, could be wrong.
I've been searching YouTube for videos but to my surprise there really isn't any good ones.
huffster329
huffster329
Fort Eustis, VA
That's why I'm here, couldn't find much information on YouTube for an 01. I have everything I need to install. I just want to make sure I know what I'm doing before I tear into that fuse box.
MadDogDelpho
Texcellent
On my 02 the headlights have to be on in order to then engage the fogs. So I figure it's wired into that.
huffster329
huffster329
Fort Eustis, VA
I do know that the fogs have their own fuse and relay in the fuse box... I believe its already wired from the fuse box to the switch. I guess I could always wire into the headlights for power, but wouldn't that mean the fogs will be on whenever the headlights are?
MadDogDelpho
Texcellent
I think you can wire to the headlights for power, so whenever they're on you have power, but wire your fog light switch in between, so that that controls the on and off of the fogs themselves.
05Single
afraid of the dark
I've heard people wire them to their parking lights too. I've found prewired vehicles are hit and miss.my 05 Silverado was not prewired for fogs
rockola1971
Indiana (formerly IL)
No, No, No and NO! You DO NOT wire fog lights directly to your headlights and you dont wire the fog lights directly thru your fog light switch. Here is why, The switch wired directly in series with the fog lights means all current passing thru the lights passes thru the switch. Most likely the switch isnt rated for that kind of current. What you should have is really 2 electrical circuits. The Fog lights wired to the normally open set of contacts of the fog light RELAY and the other side of those contacts wired to your 12v power source. All of that wiring is probably aready at your fusebox from the factory. Then you have the control circuit portion of the fog light circuit. The fog light switch is wired in series with the coil of the fog light relay circuit OR the switch gives a signsl (12v+ or possibly negative) to the BCM and ultimately the BCM gives a ground to the coild of the fog light relay. Id have to look in my schematics to tell you for sure how the factory does it. Im 1000 miles almost from my schematics currently.
Bottom line, you hook up light switch in series with the lights and you run the risk of melting wiring and/or a dash fire. There are basic wiring principles for a reason, especially in autos and the risk of fire or severe damage is great when you cut corners in auto wiring. Dont do it.
05Single
afraid of the dark
lol it's fine wired the right way with a relay, just basic oem fogs. Not some crazy 200w light bar or KC daylighters.
huffster329
huffster329
Fort Eustis, VA
That's what I'm trying to do, wire the fog lights the correct way through the relay. Just as it would be from the factory. I really don't want to melt any wiring or cause a fire. When you get back to your schematics could you find out where exactly I need to wire into in the power center? I did find an old thread where he tied into terminal 87 (purple wire) under the relay, got the BCM reprogramed, and was good to go. Here's the thread I'm speaking of. http://tahoeforum.com/showthread.php?t=524905
I don't want to start messing with anything until I know exactly what I'm doing.
05Single
afraid of the dark
The options I said are also "the correct way"
I wouldn't tell someone to do something if it will catch fire or cause harm .
huffster329
huffster329
Fort Eustis, VA
What I meant by the correct way was exactly how it would be from the factory. That's the route I was hoping to go. I didn't mean to sound like your way is the wrong way.
rockola1971
Why would you even mention this? How exactly is this the "correct way" ? Dont you think the factory would have done it this way if it was safe and met automotive elctrical standards?
rockola1971
I would first verify that the fog light relay is in the fusebox. If it isnt then acquire the correct relay. Put a meter on the normally open contact terminals in fusebox to see if one side is hot (12v). Test inside oem fog light switch to see if the switch energizes relay and closes the contacts. If not then that will need to be corrected. COuld possibly be a PCM program issue. Ill have to check my schematics to verify that one.
05Single
afraid of the dark
Yea I understand what you were trying to get at. was just reassuring you that it's fine to use the other options without getting discouraged by rockola.
I'm the same as you, if I can use an oem option I always try and go that route. But for fogs I've almost always hooked straight to the power source with a relay and inline fuse. Wrapped the wires in loom and nobody knows the difference. Just remember to turn them off when you park.
But I understand that you want 100% oem , but there's not much out there for 00-02, but sounds like rockola has your back.
05Single
afraid of the dark
lol I never said this is the correct way, little confusion. I wouldn't personally do it this way , just said I heard of some doing it this way without issues.
rockola1971
One key problem with hooking up to the parking lights circuit is that there could be a situation where total load on that circuit with the addition of the foglights could exceed the amperage rating of the fuse that feeds that circuit which of course makes ALL loads on that circuit dead. I dont have my schematics with me so I cant say for sure what all those loads would be. This is why I dont play the guessing game and try not to reinvent the wheel when GM has already done all the engineering for us. (Granted some could use improvement). Im not jumping on you 05Single, I just like to try to stay away from leading some of the less experienced (in electrical) from thinking its ok to "experiment" while they might be under the assumption that bad things cant happen. I dont want anyone here on this forum to be a Darwin award winner or end up on Google News with their K chassis flaming in the background. Its easy enough to use GM's engineering and even add any missing components that werent an option on anyones specific K chassis.
Buford bubba
