mattbta
Frisco, TX
Wow...that timing cover. Reminds me of my 99 30th anniversary trans am (LS1). I used a crowbar to keep the crank pulley from spinning while trying to break the crank bolt. Didn't realize how soft that aluminum was. Wondered why I had an oil leak for several weeks. Doh!
95escahoe
I'm having another cam installed. Hopefully that's something they do. The 6.0 is from an 05. Are the 05's known for that also?
The cam issue is pretty common on the 6.0 from what I gather, when the shop did my intake gaskets (which fixed my idle issue) if it was still there, thankfully it wasn't, it could be a worn cam which he said is pretty common on the 6.0
Hopefully I won't have to worry about that.
jarydM
Lost in the Woods
Tennessee
Noticed a week or two ago when the girlfriend was driving that the 3rd brake light was out, so I replaced it (after having to bend the pins 10 times to make it light up) with this one from Amazon.
#1taho
5150TAHO
niagara falls ont
Fuel tank is out.
Waiting on the fuel pump delivery. Cleaned off the rust and oil sprayed everything above the tank. As much as you try can never get it when the tanks in. No pictures cause there was nothing left but a pile of rust.
Here's the deal--supposed to be for 4wd....
Laying tight against the front prop shaft! I'm not happy right now. And.... They only send me 15 header bolts! WTF!?
ScottyBoy
Shreveport, La
Just ordered over $1000 in parts for my truck today. Between Rockauto, eBay, Amazon, and a huge Amsoil order, it was over $1,000.
Phlipnstik
