F*%#N Oil Leak!!!!!!
DaRosa218
The Dude abides
Modesto, California
So apparently my Suburban decided to develop a oil leak at the driver side rear of the block. I shoved my phone back there to get some sort of a view and discovered that this has been going on for quite sometime. Apparently switching to Synthetic made it worse? It's now dumping down my Block and all over the underside of my truck rendering it "Out of Service" until I replace whatever is going on. Anyone else have this problem? If so, what was your discovery and fix?
Thanks
ISU-152
I lose about 2 dots a month if it makes you feel better...99
YukonandtheHOE
From what i see its either your Oil pressure sensor Blew the oring or your vally pan gasket, easy fix either way. As far as Dino to syn oil swap, Dino in some cases will kill rubber gaskets and top shelf synthetics have conditioners in it to keep rubber nice and hydrated
DaRosa218
DaRosa218
The Dude abides
Modesto, California
LMAO, My 2000 Cadillac Escalade hardly leaks at all as well. She's been sitting on the side of the house for the last month, havent driven her much since I bought the 'Burb.
Jason_S
It could be a valve cover, oil filter, or something else. The best way to figure it out is to clean it off as best you can and take it for a spin to see where it starts to build back up. An inspection mirror, or dental mirror will help.
Unless it's literally dumping oil, I see no reason to park it until you fix it. Just keep a quart or two in a bag in the back, and check the oil level when you fill the tank. If it's low add oil. This will also help you approximate how fast you are using/losing oil. If someone drives it who cant or wont check the oil, you are probably better off parking it.
As long as you are not someone who graciously shares his music with the entire neighborhood, you will be able to hear when the engine is telling you that it is time to add oil. However, this is not the recommended way for checking your oil level.
If it's a valve cover, you need to replace the gasket. On the driver's side it can be done fairly easily. If it's the oil filter, it could just be a tad too lose. Tighten it, preferably by hand, and keep an eye on it.
DaRosa218
DaRosa218
The Dude abides
Modesto, California
Thank you for your input, It's leaking pretty decent and did a bit more looking around with a buddies Borescope and it seems to be the valley pan. I just ordered the Mahle Top end Gasket kit and going to replace everything all in one shot just as preventive maintenance. What blows my mind is the Engine was rebuilt 30K ago! Oh, well at least I know it will be done right as I am very Mechanical inclined. Only reason why I posted this up was to see if anyone else had this very issue...
YukonandtheHOE
Do you still have AFM after the rebuild?
Good time to put the updated valve cover on!
DaRosa218
DaRosa218
The Dude abides
Modesto, California
Yeah, I still have the AFM active as the Engine was rebuilt by previous owner. I am second owner, previous owner was an older couple and took extremely good care of the truck. I'm definitely going to replace the Valve Cover as I know they're also problems and get a BBP Tune to deactivate the AFM
YukonandtheHOE
You should buy yourself HPTuners, One time purchase and you can play with the ecm all you want.. down the road if you pull the heads to do a full AFM delete
rv8pilot
ABQ, NM
I had a pretty bad oil leak in my '01 Yuk which turned out to be the rear main seal although it looked to be coming from higher up on the engine. Later I did the valley cover gasket as part of replacing the knock sensors. Be sure to check them as they rust up and go T.U. There are several threads on this here.
DaRosa218
DaRosa218
The Dude abides
Modesto, California
I have the LC9 AFM 5.3L so my knock sensors don't sit in the Valley Pan as opposed to your '01, Thank God! I had a 2003 and 2005 Tahoe before so I had gone through this problem before with the oil leak and especially the Knock Sensors rusting as you mentioned.
It was definitely the Oil Valley Gasket and not the Rear Main seal as my Engine was just recently rebuilt. Looks like GM didn't tighten down the rear bolts of the valley pan to spec causing the oil leak. You can see where the oil was escaping.
Thanks for the heads up though
YukonandtheHOE
Cool,so you got it figured out and fixed up!?
johnsonwillie199
