Red
Hey Tony thanks for all your help with suspension and my wheels.
NORCAL SS'S 6" DROP SPRINGS
PAYPAL [email protected]
Springs alone $225 shipped
They will drop your 00-14 non autoride truck about 6 inches in the rear and AUTORIDE TRUCKS 5 inches in rear.
Few thing about this kit (i sell all items below)
1) you will need to run the djm hardware kit with the shorter bumpstops which is $190 shipped
2) you will need to use the belltech street performance shocks which are $130 shipped
3) You will need to cut the bumpstop bracket off the frame.
4) The springs by themselves are $225 shipped to the lower 48 states
5) Airlift helper bags fit inside also. The coil spring design I went with has no dead coils so helper bags will work perfectly and they have more of a chance to fit in between the springs. You will be able to load up truck with helper bags in the rear. Airlift 60742 is part number to work on these bags.
Yeah i have the 2200 shocks on my yukon right now. I have a djm 3/4 kit. I want the 6 inch coils but i dont want to use belltech shocks. What size calmax shock would be equivalent to the belltech shock? My ride is really bouncy
Can i have a model number for the shocks plz? I already did the bumpstop bracket delete on my truck. I have the rear kit also.the designed my springs around the belltech sp shocks and no issues with ride. You will need the djm rear hardware kit with my bumpstops also to make the kit work and cut bracket off the frame. There is no way my kit will ride right without the above set up and cutting off the brackets.
I clicked on the link and it showed some black bumpstops for $15. Now which belltech shocks do i need?you will need new bumpstops in rear which attaches to the axle in current hole or the truck will slap axle to frame
the 2410's i have those ready to roll also
I have a 2016 Tahoe LTZ (with autoride) with a 2/4 (3.5) drop installed and on 24" wheels. The rear still sits approx. 1-1.25" higher.
Will this 6" drop spring (5" for autoride) be enough to make the front and rear fender spacing equal?
What rear kit are you using?
Are they the 5305 coils?
Did you use the spacer?
Did you cut bracket off frame?
Did you do my endlink/bumpstop kot?
Are you using extenders?
