My truck rode about 2in lower when I replaced my nivomats with bilsteins. It looked cool rode smooth but didn't have any load handling ability. Even bottomed out once just driving around. Nivomats have a built in spring and you will see you cannot compress them by hand like other shocks. I replaced mine with bilsteins factory spring. Handles better than the nivomats but doesn't have the same load handling ability it did stock.
I don't really load much in it, so I'm hoping I can get by. We'll see tho. Thx for the input.
ATIII
Brighton, CO (Denver)
Didn't do anything to the truck, but bought me a taller jack today for working on it.
07-13 brakes going on this week.
Sent from the *******, mid push.
Please keep us updated. I noticed while doing my shocks that my front brakes will need to be changed soon, and I also have the nnbs upgraded brakes, along with the steel braided lines. I heard it's a real mofo to bleed the brakes. Supposedly you can only really do it with a snap on hand held or equivalent. Think that's true? Instead of bleeding the brakes the old fashion way?
DDenali
Orangeburg, SC
These trucks are a pity I work at a Gm dealership and have access to the tech 2 so I just Auto bleed and call it a day.
Sent from Dugar's iPhone 7 Plus using Tapatalk
ATIII
Is it possible to just do it the old fashioned way, and be good to go?
DDenali
Orangeburg, SC
Yes sir just a little time consuming that's it. I helped my best friend replace his front calipers on his suburban after replacing the caliper we did the traditional bleed procedure start from the furthest away from the master cylinder and so on took us and but 25 to 30 mins to bleed it was all good afterwards
05Single
afraid of the dark
I got a similar Jack from HF, works great! I think it's a 6 ton.
We don't have a harbor freight in Alaska. I miss it. We also don't have a sonic. Just got a Krispy Kreme last year.....this place is depressing :pp:
ATIII
We just got a HF out where I live now. Closest one was about 45-50 mins away.
I tried a vacuum bleeder after doing all 4 stainless brake lines but after wasting my time, I just put a piece of clear hose on and put the end in a jug of brake fluid. Then just loosened the bleeder valve and pumped away. I watched until the air was gone. Then tighten the bleeder. Start farthest away and work to the closest to the master cylinder. I did it myself, no help. I used my hand to pump the pedal so I could watch the jug.
Harbor Freight. I know, I know! I did a lot of research on it and it's getting pretty good reviews. As far as playing around with it a bit tonight, the thing is built like a tank, but surprisingly easy to steer around. I like it so far.
http://www.harborfreight.com/3-ton-daytona-professional-steel-floor-jack-super-duty-63183.html?utm_referrer=direct/not provided&utm_referrer=https://www.google.com/
The HF here wants $200 for that jack; it's on EBay for $130 shipped.
NjA4207
