Escalade/Esky Full LED 3rd Brake Light Conversion
zimeir
only running 42 LEDS not 46 LED's on my Tahoe Escalade
Using a phone cam, pics not the best
Leave in the original 20 center LED pads and hot temp glue the iJDMtoys pads on the left and right after you drill your new holes on the side of the original 20 center LED's( order iJDMtoys RED LED's )
You need 13 pads on the right and 13 pads on the left. I just ran with 10 pads on the right and 10 LED pads on the left. I left my original center 20 LED's in and neg and pos wires to the end of left and right board . The end of each L/R board pumps out 11.7V. The pads you get to retrofit your brake like runs at 12v. I bench test the LED pads for 40 mins. You can test all ur pads before install with a 9v battery. These LED SMD pads you get from IJDMtoys match with your original center LEDs lumen. LED lighting is balance , nice and clean and bright from right to left.
$28.00 for LED RED lights, 1 hot glue gun from hobbylobby, a drill and a few hours of your time and your in business.
link for the iJDMtoys LED SMD red lights below:
http://store.ijdmtoy.com/LED-Light-Retrofit-For-Headlights-Angel-Eyes-DRL-p/35-369.htm
iJDMTOY (20) Brilliant Red 12V 5050-SMD LED For Tail Lights, Brake Lights,Retrofit Use
GalaxyBlackEsky
BlackedoutLT3
MD
Looks good. I was about to say nice to see another MDer and Ravens fan until I saw it was a college.
olma13
VA
thank you
---------- Post added at 09:30 PM ---------- Previous post was at 09:23 PM ----------
and 7 more posts until i can even message him..bummer
soulsea
Bar
You might be able to PM him at the hidplanet forum.
93blkongreenpro
Vegas did this one that I bought from a memeber a few months back. It is bright as hell and I see why GM did not run them all the way across.
Sent from my SM-G935P using Tapatalk
a1parrothead
