Knope
NC
Finished installing the lower bumper lip and halo headlights
SnowDrifter
Sasquatch Country
Broke it. I put a corvette servo in it. Idle, warm up, no leaks. Drive it through the neighborhood, no problems. Get on the main road, all is good. 2 miles out, I get up to a place where I can get to 4th, there is no 4th. So I go to turn around, then find out now I don't have 2nd. Pull over, look underneath, it's pissing fluid. SO yay me. I'm hoping 4th is a fluid pressure issue from something not sealing and not something else I fuckered up.
What do you think happened? Could you see where it was leaking from? Hopefully it's OK.
SnowDrifter
Sasquatch Country
Looks like I didn't have the snap ring for the servo cover fully seated. Cover was jammed at an angle and pissing fluid.
The seal for the 4th apply piston was pretty messed up. Not sure if it was during assembly or or when the cover went cockeyed under pressure. That explains why I didn't have 4th. I'm assuming loss of 2nd was due to fluid loss since it worked at first.
Don't rush things, take your time. I tried to shave a few minutes off and get things done quickly.
DDenali
Orangeburg, SC
Damnnnnnn
SnowDrifter
Sasquatch Country
Local chevy dealer parts counter guy didn't have a clue what I was asking for. Couldn't find it when I gave him a part number so I just ordered the seal online. Worst part is the wait, having no car sucks
DDenali
Orangeburg, SC
That's always the worst part hope you get it fixed soon bud
Sent from Dugar's iPhone 7 Plus using Tapatalk
GM Part# 1092185
Thx:waytogo:
Tonyrodz you want the lower valance that he has on his Denali correct?
Yup, they look the same, hopefully.
Hopefully once you get it together you'll be good to go! Shit always happens when you're trying to rush things. Never fails. :whymewhyme: Good luck man.
Mountain Rambler
