I'm looking to lift the front end a little more and figures between these struts and my rc lower strut spacer I could find a nice height that doesn't give to bad of angels. Does anyone have any experience with what clip level gives how much lift. My lower ball joints have a little play so I figured since I'm doing that I might as well do better upper control arms to deal with the added angle (probably will be the rough country uppers) along with new inner and outer tie rods. Since I'm doing that I might as well do struts since I have 160k on it. I'd like to be somewhere around 3-3.5 inches of lift. I will get/make spacers to drop the front diff to.
Right now it has the lower spacer that gave it 1 3/4 and maybe a hair more lift up front nothing in the back. All 4 corners are 38" 275/60r20. I'd be putting a 2-3" spacer on the back depending on what I end up doing with the front. Planning on using a 2" wheel spacer and my stock wheels for now then 20x10 around -19 so they have a decent size lip and some 33/12.5 or a little larger if I can fit em.
