shakedown067
Was there a reason why you didn't use your radio for the backup camera?
Haven't ordered my back up camera yet. Need to though, but it'll work with the head unit.The rear view mirror has a front camera and DVR. Here in Florida you to record everything like those crazy Russians do.
05Single
afraid of the dark
Thats awesome , got a link for the one you have ?
shakedown067
I downloaded a couple of vids off of it, but need to upload them. I can take a couple more shots later for ya.
Just got my knock sensors in.
ScottyBoy
Shreveport, La
Just got my knock sensors in.View attachment 71255
Get the harness too if you didn't already get it. Trust me, you will want to replace it as well. And be sure to use a torque wrench to properly torque the sensors down. Too tight and they will give you false knock codes because they will be overly sensitive. Not tight enough and they can still give a fault, plus work their way loose too. I forget the exact specs, but it's all over the internet. Good luck replacing those bastards. They took me two solid days, but I probably could have done them in 6-8 hours if I didn't have a bad back. I have to keep stopping and take a break. Plus I spent the time to clean EVERY spec of dirt and grease off the intake manifold while I had it off. I sealed the sensor rubber plugs/covers with blue RTV and I let it cure overnight then reassembled everything the next day.
Knope
NC
Turned torsion bolts up and got an alignment. Needs a bath terribly, but it's just too cold for me to do it.
TM98
Oh wow I didn't even realize that was a front facing one.
DDenali
Orangeburg, SC
I'm not sure I was guessing at what model that was lol [emoji23]
Sent from Dugar's iPhone 7 Plus using Tapatalk
Merch619
