RENAMED!! The adventures of Chase and his 2006 Yukon XL Denali!! Follow along on my travels!
So Monday evening turned out to be an adventure that I didn't want to go on. Lol. In August of 2015 my starter gave out. Replaced it no big deal, well Monday afternoon I stopped by the self car wash to rinse my rig off. Went to start up and no go. Turned over real slow and en just clicks. Ugh....been down that road. Lights are on, stereo starts up, so battery has juice, starter is kaput. Damn, it's only been a year and four months. Ugh. Well luckily my starter came with a lifetime warranty from Napa auto parts, apparently because they don't last long and give out pretty quickly. So in the dark, and 30 degrees in the parking lot of the self car wash, I rip my starter out, walk the 2 minute walk down the street to where the parts store is, fortunately it was close by, and they swapped out my starter with a new one that thus had in stock. Walk back, wrangle the new starter in, boom Denali fires right up. No check engine light or funky codes. But not exactly how I wanted to spend Monday evening. And in another year that starter will probably give out. :banghead:
Probably after Christmas I'll pick up a better brand starter so that it doesn't give out in a year, but gota wait till I get into full swing of ski season and through the busy period through Christmas and New Years when the dough is flowing in. Lol.
Now THAT sux!!
That must have been a ***** to do. I've never replaced a starter in one of these but I've read that it's hard. I'm sure even more so in your case.
adventurenali92
adventurenali92
Big Bear Lake, ca
It's reachable at least. I was in the market to try and buy a limited model Toyota sequoia before I had started looking at the Denali. And I'm glad I didn't end up with a sequoia. The starter on that sucker is buried under the intake manifold. Its a really bear just to get to it. On the 6.0 it's just behind the front passenger wheel. But in the dark it sucked. Although this time at least I was on clean pavement. But no problems since the starter. Now hopefully I have time to work on fun stuff for the rig! :cool:
Fosscore
Man that is some good work changing that sucker out in the dark. Guess it is time to upgrade that under hood lighting to some cool LEDs like @05Single ? lol
Fosscore
Mine neither. Needs it if nothing else because it would be a cool mod and look good.
And who doesn't like a cool mod that looks good and is functional. :)
I don't! Jk. I have one if those underhood lights from an obs that you can roll out, all the way to the back of the truck. I was think of trying to get it to work on our style rig.
adventurenali92
adventurenali92
Big Bear Lake, ca
Nopemine doesn't have any lighting. Althought there's a wire of some sort attached on the drivers side of my hood. Any ideas what it's for?
adventurenali92
adventurenali92
Big Bear Lake, ca
I've also discovered a new issue that needs to be addressed. My cup holder tray is somehow broken. The side piece that fits under the lid where the cup holders and ashtray sit is no longer attached on the right side to the bottom of the gray trim bezel. It sags slightly. I noticed on my way home from a work a slight gap in the smaller lid that covers the outlet and tray cuz it was closed and not flush. Here's a couple pics. Any ideas on how to fix it? Also any idea how to make the whole thing apart? I can see a bunch of stuff that I presume fell through the cracks in the trays from my rigs previous owner. Would like to clean all that out. First pic is of the lid not sitting flush as the whole tray says towards the passenger seat. And then second pic is the area under the topside grey trim bezel that I presume is where the cup holder piece so supposed to attach.
The piece attached to your Hood should be a ground strap. I don't really know how your center console top comes apart, but it can't be too hard. The door that doesn't fit flush probably has a small tab on each end where it snaps into the body of the console itself. One either popped out, where it could be, carefully, popped back in, or it might've broke, where you'd probably have to buy another door for it. I hope I'm making sense.
Make sure the interior is nice and warm. Plastic gets brittle in the cold and could crack or break worse if you apply any pressure to it. Sorry I couldn't help more.
adventurenali92
adventurenali92
Big Bear Lake, ca
It's weird. The flip cover itself isn't broken. Its the whole tray beneath that holds the ashtray and cup holder is what's not attached to the trim piece above it that wraps around the cup holders and under the center console lid. It's super weird. Only weird stuff like this happens to me, I swear! :confused:
TheAutumnWind
Ezdaar used to sell kits for underhood lights, he pulled power from that maybe?
Are you saying you want a under hood light?
I make and sell this kit. Its 90% PNP.
All you need to do is drill the hole for the switch and run the wires theough existing conduit.
Once done. Its practically invisible.
Everything is soldered and double heatshrinked. Absolutely no ****** crimp connectors or electrical tape.
My silverado, all my kits but the tahoe below are like this.
Tahoe with a oem hood light.
Yea, power wire is behind the insulation and then down through the hood ground wire conduit.
There is no hood pin switch.
I could and would love tp tell ya more. But i am selling these and its my secrets on how i build them.
Its not terribly difficult, so of your smart and take your time. You will figure it out.
So good luck.
adventurenali92
adventurenali92
Big Bear Lake, ca
@TheAutumnWind ,that's awesome! Would not be able to do that myself as though as I'm not good at messing wires and running them lol. But maybe a future mod for a close family friend that's been a mechanic for years who will work on my truck. And he likes to do upgrades like that too.
TheAutumnWind
Yeah i've heard about that with some toyotas. Doesn't sound fun. I used to cook starters on my IROC back in the day with my headers that ran right next to it. Bought a lifetime guaranteed one from autozone and they just kept replacing it. Its in the same spot as on these trucks and there is more room to get underneath so They aren't terrible. Glad you got yours fixed up.
Drewphil
