#1taho
5150TAHO
niagara falls ont
I would check back with Nelson. I think they hook up differently. I read people has some issues hooking up aftermarket harness, not just nelsons.
a4edwin
ny
I didn't get it new I got it as part of a turbo kit I bought which included the harness and the fans. Just ordered a new one from nelson.
95escahoe
Installed a Airaid MIT, cleaned the MAF and TB too
Factory intake setup
The TB all cleaned up
MAF back on
All done
jarydM
Lost in the Woods
Tennessee
Bought a set of these to give a bit better look, and a bigger wheel for lift ( later) and larger tires (eventually)
a4edwin
ny
Just got the new one from Nelson today. The new one compared to the old one looks completely different. Like homemade to professional different. Prob won't have time to switch them today but ill post as soon as I do
mattbta
Frisco, TX
Finally installed new GM lower and upper intermediate steering shafts put in. Put the dorman bearing in and it was a PITA to get in, the bearings kept coming out inside the plastic. Also attempted to put in a delco steering position sensor, but it wouldn't go in all the way and I inadvertently broke the little tab off. Gave up and put it all back together without sensor for now. Trying to decide if I want to take it somewhere and if so, also get a delco bearing.
Smoke Em All
Taylor,Texas
Well I pulled the wheels on my 05 to do a new brake pad swap and realized my old brakes were fine. The shim was rubbing the rotor causing the squeal. Also finally got around to scraping the plasti dip off the roof rack. Still needs some cleaning but looks a lot better.
1992rs
OR
Installed my cognito brace on my idler arm side. The hellwig sway bar mounts farther away from the oem one so I was able to get the brace in there and it's millimeters away from sitting on the bar. It just might hit at full lock but they'll work themselves out.
I took a trip to the other side of Portland and was amazed at how nice it rode even on the poorest of roads. Bumpsteer is down to almost nothing, drives straight, rides smooth as glass, steering is pin point precise. My rig is starting to shape up to a nice driving truck.
Knope
NC
Replaced the license plate light assembly and added LED bulbs. So bright!
Merch619
